Headlight Upgrade - Page 2 - Defender Source
Old July 30th, 2009, 11:27 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Originally Posted by merlin8ty
Made the decision. Although the xenons would be cool, I spoke with a guy from Susquehanna and he said in new york i would have problems getting pulled over for them. 6k fine, take the truck, basically a big pain in the ass. He recommened this set up.
H6024
H6024 7" Round E-code Hi-Lo Conversion Headlamp Kit.
Choose H4 Bulbs : H6024H 70/65W Osram Hyper
He said you will see a drastic improvement and still get the look of xenon. It seems they really know their stuff.
You'd get even better performance out of a non tinted bulb, but if the HID look is what you are after...
~Scott T.
'95 D-90 ST - AA Yellow
Old July 30th, 2009, 01:10 PM
akfisher
robert hall
95 d-90sw
FWIW when i went to upgrade my headlights the guys at expedition exchange talked me out of the heavy duty harness and just sold me the hella e-codes as a drop in replacement. they were a big improvement and i have had no problems for a year now. admittedly i dont turn the headlights on very much up here in the summer.
Old September 23rd, 2009, 02:27 PM
Landrover90
Glenn Wegener
1994 Defender 90
Check these out!
http://www.xsighting.com/products.html
These are HID headlamp replacements normally used on muscle car restorations.
Serious $$$$ but so sweet.
1994 Defender 90
Old September 23rd, 2009, 08:02 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Can someone confirm that the 97 had a proper wiring harness? I am not sure why you would need to buy a different harness when a couple of relays and wire would do the trick? Or am I missing something?
Old October 12th, 2009, 06:38 PM
GMFett's Avatar
GMFett
Marcus
1994 D-90
Are the Sylvania H6024 Xtravision acceptable replacements in terms of wattage and wiring?
Old October 12th, 2009, 07:06 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I know this is not pimptackular D style, but if you replace the bulb in the standard Rover headlight with a motorcycle bulb it will be as brignt as almost any bling light out there. 90 watt lows if I remember right. They were $9. Have to slightly mod the plug.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 13th, 2010, 11:48 AM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
Buck, does using a motorcycle bulb require upgrading the harness?
Abe
Old February 13th, 2010, 12:47 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Originally Posted by Landrover90 View Post
Check these out!
Why not just go LED at that price? Less draw on the wiring, switch and alternator.
Old February 13th, 2010, 01:01 PM
Actually HIDs use less power for the equivalent light output than LEDs.
Old February 13th, 2010, 01:53 PM
j0nny216's Avatar
j0nny216
Jon Kleppel
1994 D90
Is the ARB/IPF heavy duty wiring harness long enough to run to the the underseat battery? Just curious if I will need anything extra...
Old February 13th, 2010, 02:53 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Anyone tried the Truck-lite 7inch LED Headlight?
------ Follow up post added February 13th, 2010 02:57 PM ------
Looking at the photos of them - I have OR lights like that and they are so intense I can't look at them directly and they give off no heat.
Old February 13th, 2010, 06:42 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
You sure about that? The trucklite LED at low beam is 2.5 amps. Last I checked, most HIDs can't be purchased for less than 35 watt, most are 55.
Old February 14th, 2010, 11:57 AM
Trucklites are 30/55 Watt. http://www.truck-lite.com/webapp/wcs...4057&langId=-1
35 watt HIDs are much brighter than the Trucklite LEDs
The Trucklites apparently don't have a great light pattern. The lighting gurus say that a decent quality halogen is better.
http://www.mge.com/home/appliances/l...comparison.htm
Typical HIDs run around 90 lumens per watt.
Old February 15th, 2010, 08:19 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Why not try the new LED headlights?...
Old February 15th, 2010, 09:49 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I've ordered a pair of the LED headlights - I'll post some jpegs and comments when I get them. Next week I was going to install a new HID bulb setup in my other defender and I should be able to compare the two side by sidey
Old February 15th, 2010, 01:53 PM
Backstay
John Hilton
1994 D90
If any D-90 member wants some quality high powered H4 bulbs, I have some 90/135w units on special. These are the bulbs that come in the PIAA 80 Series Racing lamps which are well proven off road. I've also got a deal on 7" round Bosch motorcycle approved headlamp units. $20 each for the bulbs, $40 each for the headlamps.
Old February 15th, 2010, 05:43 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
post back on the results Chris...
Old February 15th, 2010, 06:43 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
I put a pair of Sylvania Silverstars in a '97 and it was fantastic, and they were in stock at all the local parts stores.
Old February 15th, 2010, 11:15 PM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
I've put these on my Td5...GREAT result and nothing crazy re: install
http://www.roundeyes.com/Jeep_Headla...Headlamps.html
Aiming to do so on the RRC as well
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
Old February 17th, 2010, 02:21 AM
CDeWan
Clay DeWan
5.3L beastie
light upgrade
first went with the auxilliary wiring harness that pullled power from the starter. Use H-4s Superwhites and Hella E codes - bery nice.
not enough though
Purchased Hi and low beam HID's from Group5motor sports in San Diego. Went with a 4000 as to avoid the blueish tint and "Damn Gina" these things are awesome. The HID kit runs around $200. Well worth it.
ht
OME upgrade advice kolvedic Defender Technical Discussions 11 August 16th, 2005 11:08 PM
97 defender st - headlight retaining screw Rob Defender Technical Discussions 1 April 25th, 2005 06:22 PM
Mesh Headlight Guard NashvilleRedD90 Defender Technical Discussions 5 April 18th, 2005 03:20 PM
Upgrade pushed back chrisvonc Misc. Chit-Chat 0 May 15th, 2004 11:23 AM
headlight switch sub jorge Defender Technical Discussions 1 January 24th, 2004 09:10 PM
