headlight switch sub - Defender Source
Old January 24th, 2004, 07:30 PM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
My headlight switch stopped working due to a combo of wear and possible small meltdown around the headlight contact. I just replaced my headlight switch with a simple 3 position toggle switch as an emergency repair,I 'm thinking of leaving this as a permanent fix as it feels stronger and firmer than the orig switch.Has anyone tried this ,any pros and cons to this setup.
Old January 24th, 2004, 09:10 PM
artm
Arthur Maravelis
97 SW
Sure, it should be fine. Stick in a diode to get just the parking lights in position 2 and also the headlights in position 3.
I just replaced mine. I got the 94-95 style since the 97 wasn't available - and it was quite cheaper.
I used the connector from the 97 and crimped the wires with heat shrink around them. Good as new!
I got it from these guys - only $40:
http://www.northeastbritishparts.com/
ht, switch
Aux. light switch (RRC headlight switch) $40 shipped evilfij For Sale - Parts 0 September 5th, 2008 05:12 PM
Headlight Switch Issue, any ideas? januconn92 Defender Technical Discussions 1 July 24th, 2005 11:53 AM
94-95 headlight switch.. can be broken TDI Guy Wanted 4 May 17th, 2004 06:28 AM
