Headlight Switch Plug HOT/Melting - Defender Source
Old May 14th, 2016, 12:47 PM
Fred Lobster's Avatar
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
I've had to replace the headlight switch a few times, on my NAS 110, due to the internals of the switch getting hot and melting some of the plastic components. As a remedy, I installed the ARB relay kit hoping that would save my switch from future failure. Since installing the relay kit, the lights are extremely bright and may need to be adjusted, as I constantly have oncoming traffic flashing me, until I hit my high beams....which are quite impressive.
Anyway, I have since noticed that the headlight switch plug, and wires, are getting extremely hot and causing the rubber plug to melt a bit, to the point of having to twist or hold the plug in an exact position to keep the headlights on while driving at night...
I thought the relays were supposed to eliminate the heat transfer up the wires to save my plug, but I guess that is not the case. Any recommendations?
Old May 14th, 2016, 01:50 PM
bish1865
Bruce Bishop
1985 Defender 110
Sounds like grounding issue to me also. I converted my defender head lights to the relay system. No more heat and very bright head lights. But I have had over heat issues with corroded connections with the early defender. Clean the connections and a little anti corrosion should help.
ht, switch
Hot headlight relay, brake light issue... RX6RCROL Defender Technical Discussions 5 March 22nd, 2016 03:28 PM
Fog or Aux Light Switch/Plug & Switch Plate DPdotCOM Wanted 8 February 22nd, 2016 01:36 PM
Rear Defrost Switch, Rear Wiper Switch, and Rear Wipe/Wash Switch bradfordish For Sale - Parts 5 January 26th, 2014 12:30 PM
Aux. light switch (RRC headlight switch) $40 shipped evilfij For Sale - Parts 0 September 5th, 2008 05:12 PM
A/C Help......hot, hot, hot! boulderbear Defender Technical Discussions 7 August 26th, 2006 07:54 PM
