Headlight Switch Issue, any ideas? - Defender Source
Old July 24th, 2005, 09:30 AM
januconn92's Avatar
januconn92
Jan Jurgielewicz
97 D90 #1477 Green ST
Headlight Switch Issue, any ideas? - FIXED !!!
Hello All,
Well finally got my truck back after a short in the frame wiring !!, yesterday I noticed by steering column cover was loose, I tried tightning, but I think I clipped a wire with the screw and saw a spark, now my headlight swtich does not work, all other electrical seems fine. No positions on the switch work (1st for park lights does not work).
question, did I blow up the switch?? Is there a fuse for that switch? If so which one and is there any sure way to rest the switch?
Thanks in advance for any suggestions...
jan
Old July 24th, 2005, 11:53 AM
januconn92's Avatar
januconn92
Jan Jurgielewicz
Turns out it was the 30amp bus fuse, big one in the engine compt. fuse box...
all fixed...
ht, switch
Aux. light switch (RRC headlight switch) $40 shipped evilfij For Sale - Parts 0 September 5th, 2008 05:12 PM
94-95 headlight switch.. can be broken TDI Guy Wanted 4 May 17th, 2004 06:28 AM
headlight switch sub jorge Defender Technical Discussions 1 January 24th, 2004 09:10 PM
