Headlight relay - Defender Source
Old June 10th, 2011, 12:33 PM
Palomino
Rico Palomino
1995 D90 SW #001
Headlight relay
Headlights went out lastnight at 0130hrs on a counrty road. Used a flashlight out the window to make it home. Mrker lights work at halfway position but go out when pushed all the way forward. Brights work when pull the flasher on the turn signal arm. I figured its the infamous headlight switch that went out.
I ordered a new one but did not find anything about the ARB relay that everyone recomends.
Were can I order the relay from?
Rico
1995 D90 #001
Old June 10th, 2011, 12:52 PM
TS888's Avatar
TS888
Tony Sims
1984 110
It's an ARB harness with relays, that takes the load off the switch and prevents a recurrence of this problem, as well as giving you brighter lights.
You can also make your own, equally effective and much cheaper. Search the forum for "ARB headlight harness" and you'll find info.
Tony
1984 110 "Smokey" (sold)
Old June 10th, 2011, 01:07 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Double check that your headlight dip/dim stalk is not bad. I had this exact problem (symptons) on my Series and it was the dip/dim stalk. (I also used a flashlight out the window to get home - LOL)
Firemanshort
1980 Stage One 109
Sterling, VA
Old June 10th, 2011, 05:39 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
so is the Susquehanna motor sports version, very easy install (so I'm told) http://www.rallylights.com/detail.aspx?ID=1247
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old June 10th, 2011, 05:53 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Definately sounds like the switch to me, I installed an HID kit with seperate ballasts to solve my issue. So far they work, switch hasn't burnt out yet but its only been like 2 weeks so we shall see. Do yourself a favor though, they are only like 14 buck each for the switch be sure to buy 2 of them and keep one as a spare lol. Anyway, HID is cool, xenon bulbs are super bright!
Robert Deniro
ht, relay
Headlight insurance for around $20. (USD) LenB Smaller Projects 7 October 9th, 2008 12:59 AM
AC relay in passenger area? artm Defender Technical Discussions 0 July 18th, 2005 09:53 PM
Relay replacement help cgalpin Defender Technical Discussions 21 April 18th, 2005 07:42 AM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
headlight switch sub jorge Defender Technical Discussions 1 January 24th, 2004 09:10 PM
» Defender Registry
Oink
Akitatw4
110
Rugbier
Add your Defender
