headlight problem - Defender Source
Old April 21st, 2005, 05:40 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
headlight problem
After playing around with my dash, my main headlights are not working but the high beams are. What could that be?
THe switch is working and so is the relay.
Legend in My Own Mind.
Old April 21st, 2005, 09:01 AM
Check the connections at the ack of the relay, make sure that there is 12 volts comming in to the relay and going out to the headlights. We can look at it at RC if it still isn't working.
Old April 21st, 2005, 05:03 PM
neo812's Avatar
neo812
Kris
1985 Tithonus
Check the relay behind the dash. It controls the low beams.Not the one by the fuse panel.
Old April 21st, 2005, 05:56 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
check the fuses. The high beams are seperate from the lows, I had the problem in the reverse. My left high beam was not working but the lows were. It ended up being a fuse. Just a thought.
Old April 21st, 2005, 06:04 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Fixed it. one of the wires on the directional stalk came off. All is good.
Old April 21st, 2005, 07:12 PM
sheki's Avatar
sheki
David Shechter
that was going to be my next suggestion
ht
Remedial Tech- Headlight Change Problem gtg067i Defender Technical Discussions 3 January 25th, 2006 12:03 AM
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
headlight switch sub jorge Defender Technical Discussions 1 January 24th, 2004 09:10 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
