headlight issues - seeking some advice - Defender Source
Old September 21st, 2013, 01:38 AM
akrockhound's Avatar
akrockhound
Jack
1988 RHD 110
My '88 110 (RHD, V8) started showing some electric issues and wanted to get some advice before I starting tearing into it.
Everything was working fine until yesterday
First the front headlight quit (low beam) but high beam still worked
checked bulb - all was well
checked fuses - OK seems like there is power to the fuse box for each light
I started flicking the headlight switch and if I leave it on, the LEFT headlight quits all together (high and low) but if I shut everything off for a couple minutes the left works fine but no matter what the right low beam is inop.
Wiring behind the lights looks intact.
I suspect its the switch on the steering column and I have a new replacement but thought I'd see if anyone thought I should start somewhere else.
Also when I flip the headlight switch on/off I here another click (relay?) that sounds like its coming from behind the instrument cluster - What is that? I figured the wiring from the light switch would go straight to the fuse box or lights but it sounds like another electric part in the panel related to the lights. Can anyone tell me about that?
Appreciate all your help - Thanks
advice, ht
New Defender 90 owner seeking advice Roverenvy Misc. Chit-Chat 10 January 29th, 2013 09:47 PM
Rovers North Front Headlight Guards $180 Wolf Fabrication For Sale - Parts 2 November 2nd, 2011 08:41 PM
Headlight and electrical issues. tomaco1 Defender Technical Discussions 7 October 24th, 2011 09:08 AM
Newbie: Seeking RR purchasing advice kelias3479 Defender Technical Discussions 27 September 21st, 2009 05:00 PM
headlight switch sub jorge Defender Technical Discussions 1 January 24th, 2004 09:10 PM
