Headlight issue - Defender Source
Old September 4th, 2016, 05:57 PM
1987 Defender 110
Headlight issue
Having trouble with my headlights (non LED)
Driver side only works on high, passenger side only on low. Swap the lights and I get the same so it's the wiring but not the lights.
There are red, blue & yellow wires leading to each light.
I can't wrap my head around it. All I can tell is that the wires go back to teh headlight switch in the dash. What am I missing? I feel like an idiot for even asking but I'm having trouble figuring out where to start.
ID:	157001   Click image for larger version
Old September 4th, 2016, 07:05 PM
Been there. Make sure all those plugs are all clean and plugged in. Mine was a dirty ground plug.
LED Headlight Issue Jonesy Defender Technical Discussions 4 June 5th, 2016 05:01 PM
Battery Issue or Charging Issue? icnsltmfg Defender Technical Discussions 4 May 19th, 2016 12:25 PM
Hot headlight relay, brake light issue... RX6RCROL Defender Technical Discussions 5 March 22nd, 2016 02:28 PM
Trucklite LED headlight issue Paul K Defender Technical Discussions 21 January 17th, 2016 06:52 AM
Headlight Switch Issue, any ideas? januconn92 Defender Technical Discussions 1 July 24th, 2005 10:53 AM
