Headlight failure alarm sounding when headlights switched on. - Defender Source
Old December 9th, 2014, 05:04 PM
landroversrs1
Jim
Defender 90 V9
Hi there,
My 2000 TD5 has headlight problem after disconnecting a trailer recently all failed.
affter switching the ignition on & off all came back on.
However on my way home from work a few days ago they failed completely.
When the headlight switch is activated the alarm sounder goes off,.
The switch & main beam switch & stalk have been replaced problem still remains.
All fuses earths checked dim dip bypassed relays & checked trailer socket disconnected as corroded.
Voltage meter connected to the brown headlight feed gives 11v engine running 13v but when the switch is activated or the alarm red led (now dim)on the speedometer activates the voltage drops to 3v alarm sounder goes off.
Any suggestions?
Old December 9th, 2014, 08:24 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Have you checked the grounds at the right rear of the truck? I would also check the interior light switch in the drivers door.
Old December 10th, 2014, 09:08 AM
landroversrs1
Jim
Defender 90 V9
Thanks for the reply I will check.
Old December 12th, 2014, 05:13 PM
landroversrs1
Jim
Defender 90 V9
Fixed at last.
I gave up on trying to trace the problem any further,r owing to starting another tour of shifts, and using my rest days up getting wet & cold.
I dropped the land rover off at a long established specialist who took a further 4 hours to trace it to a fault in the headlamp blue/ red cable, and fix it with a new section cable.
Thanks once again for all the advice.
ht, lights, switch
Aux Fuses Switched? aosias Defender Technical Discussions 3 April 2nd, 2010 11:16 AM
I'm f'ed in the a... Switched the battery terminals vesparover Defender Technical Discussions 1 September 2nd, 2008 09:42 PM
Alarm Uninstall texasdefender110 Defender Technical Discussions 1 January 12th, 2007 12:22 AM
D90 Alarm System? icurnmedic Defender Technical Discussions 4 May 30th, 2006 12:26 AM
Switched 12v ignition and drive? dmarchand Defender Technical Discussions 4 December 23rd, 2004 10:23 AM
