Headlight conversions H4 vs High wattage - Defender Source
Old October 11th, 2012, 01:32 AM
Spook's Avatar
Spook
Rich
97 Defender 90
So my passenger bulb went out and I am thinking well....while I am at it do I need to upgrade. Any one have opinions on the British Pacific H4 conversion or the high wattage conversion?
http://www.britishpacific.com/groups...ghts&year=1997
And do my like the e-codes vs some other brand? I have always been a sylvania.
Thanks folks!
Old October 11th, 2012, 05:30 AM
The hella ecode is the housing, you can use whatever H4 bulbs you want. A lot of people run higher wattage bulbs, I have been pleased with the stock wattage and ecodess. If you opt for higher wattage bulbs you will want to run the lights through relays. ARB makes a harness. This has been discussed at length.
Old October 11th, 2012, 09:05 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Running the plain old 55/60W bulbs in the Hella lamps just now.
They're through two relays and fat wires just in case.
I ran...sheesh what were they...130/85's in the 1970's (in Marchal lamps) but that was when I actually drove fast at night
Not so much any more!
Old October 11th, 2012, 09:14 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I had the glass on my ecodes break during a winter wheeling event that involved a lot of water...switched to the trucklites and have been very happy. Either one works very well with just a standard bulb
Old October 11th, 2012, 09:30 AM
I have DOT ecodes and the passenger side cracked after deep wading at Rausch.
I'm still running the cracked headlamp, and aside from the cosmetic aspect, it doesn't seem to be problematic otherwise.
So I guess if you plan to do wading, avoid the ecodes.
Old October 11th, 2012, 09:52 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
I am running those IPF H4 lights. I bought mine from EE a few years ago. They are great compared to the stock lights and take nearly no time or effort to install.
Don't drive during the day time offroad in winter conditions that involve water. Simple solution to the light breakages. If the lights aren't at a higher temperature, they won't break when cold water hits them.
You little rebel, I like you.
Old October 11th, 2012, 09:58 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Agreed that this is not a best practice but sometimes unavoidable!
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
True statement.
Old October 11th, 2012, 11:20 AM
The $12 walmart/pepboys lights work fine. You should invest in a relay kit first.
Old October 11th, 2012, 11:34 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
THIS!
-Jeff
was "THIS!" supposed to link to something
Mike Hammond
Old October 11th, 2012, 12:12 PM
Amazing how people so young can have such a hard time seeing at night. Wait til you turn 50, you'll have to have ten of those suckers on your bumper! Bammmmm-Beee!
Old October 11th, 2012, 12:28 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
x4 (5?) on the relay. Made a HUGE difference in the amount of light (let alone reliability) http://www.defendersource.com/forum/...ad.php?t=33230
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old October 11th, 2012, 03:46 PM
UnfrozenCaveman
Keith Armstrong
Various
Originally Posted by o2batsea View Post
Amazing how people so young can have such a hard time seeing at night. Wait til you turn 50...!
Fifty!?
You're still a pup
Old October 11th, 2012, 04:04 PM
Spook's Avatar
Spook
Rich
97 Defender 90
Seems like most are opting to go with the high wattage kit since it comes with the harness and h4 conversion. Just need to get the bulbs.
Old October 11th, 2012, 04:10 PM
One thing to be aware of is that none of the H4 lights are waterproof. If you do deep wading, they will fill up with water. There are some other options if you want waterproof, but they cost more.
Also note that ALL high wattage bulbs have very short lives. If you plan to drive a lot with the lights on, be aware that bulb replacement will be a regular occurrence.
Old October 11th, 2012, 04:17 PM
This is why I like the cheapo walmart specials. They last forever, are cheap, sealed halogen beam so no water ingress, and have good light.
Old October 11th, 2012, 04:31 PM
I suppose. BUT the light of a quality H4 headlamp IS MUCH better.
I'm running a light that has a modern 9007 bulb. These bulbs are fully sealed by design and have a much longer bulb life. Light output and pattern is much better than a sealed beam.
These ones: http://www.truck-lite.com/webapp/wcs...3781&langId=-1 They are the OE lights for a Hummer H2.
Old October 11th, 2012, 04:35 PM
I suppose. BUT the light of a quality H4 headlamp IS MUCH better. I'm running a light that has a modern 9007 bulb. These bulbs are fully sealed by design and have a much longer bulb life. Light output and pattern is much better than a sealed beam.
John you lost me when you said they are sealed and much better than a sealed. can you elaborate how they solve the wading problem?
Mark Kellgren
KM4BOR
Old October 11th, 2012, 04:44 PM
The 9007 bulb has an o-ring designed into it where it enters the housing and the housing has a Goretex vent to prevent pressure buildup.
H4 on left, 9007 on right: http://www.red90.ca/rovers/Bright_Dr...lb_Compare.JPG
evilfij was talking about "sealed beam" lights. These are the ones without a removable bulb.
Old October 11th, 2012, 05:02 PM
Got it. Recommendations on converting? Does the glass housing need to be converted too?
Mark Kellgren
KM4BOR
conversion, ht
Rovers North Front Headlight Guards $180 Wolf Fabrication For Sale - Parts 2 November 2nd, 2011 08:41 PM
WTB Headlight and high beam switches for 94 D90 easy Wanted 2 October 15th, 2010 04:40 PM
Hella H4 E-code Headlight FlaD90 Defender Technical Discussions 5 July 22nd, 2010 07:34 PM
7" Marchal H4 Headlight RoverDude For Sale - Parts 0 May 7th, 2010 12:57 PM
