Headlight and electrical issues. - Defender Source
Old October 22nd, 2011, 07:38 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I just put a TD5 body and loom onto a 200tdi frame, I got rid of the ECU but hooked everything else up, The problem I have is that the headlights are on all the time, when I turn the headlight switch on, only the marker lights on the right side of the truck come on . Everything else, heater, wipers, ignition seems to work fine.
Any ideas would be greatly appreciated
Old October 22nd, 2011, 09:12 AM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
Did these originally have daytime running lights?
Old October 22nd, 2011, 09:36 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Td5 headlight wiring doesn't go through the ECU at all, it's totally separate like older rovers, so sounds like there could be a fuse or 3 missing/blown if the headlights don't come on (each headlight has 2 fuses, dipped and main beam)
There's also a relay, ignition fed, that turns the headlights off when the ignition is off (sidelights stay on), and some models also have the dim/dip headlight, which is, if you have just "side" lights switched on, with the ignition on, then the main headlights also illuminate at 1/6th brightness; this was some law we had in the late 90's and 2000's which has now been receeded. This is operated by a pink coloured relay behind the dash binaccle, in conjunction with a hefty great wirewound (gold coloured usually) resistor under the RH front wing.
There is a bypass for the dimdip, which is a *special* part; externally looks like the large 7 pin relays, but inside is just a link between the blue/red wires on that relay socket behind the dash. just short the 2 main pins out to make the headlights operate normally... as in, they'll still go off if you turn the ignition off, but the dimdip stuff won't operate.
you got the Td5 wiring schematics? PM me your email and i'll fling the .pdf document over (4.5mb)
Old October 22nd, 2011, 09:44 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
It's not daylight running lights, I was thinking that to, because they go on as soon as the battery is connected
I think dieseljim has hit on what the problem is. They are very dim when I connect the battery, about 1/6. I guess j just need to figure out how to shut them off.
Thanks. p
Old October 22nd, 2011, 08:00 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Did you maintain the security system ECU?
Land Rover 110
Old October 22nd, 2011, 08:31 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
it is still hooked up at the moment
Old October 24th, 2011, 08:28 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Now I'm wondering if the Alarm ECU is my problem.
Old October 24th, 2011, 09:08 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Shouldn't be.... Td5 alarm only flashes the 4way lights when it's going off... not connected to the main lights at all.
electrical, ht
Damn! Cannot figure out what is wrong with the lights! solihul Defender Technical Discussions 11 October 26th, 2017 07:04 PM
Electrical Gremlins- Post rain storm JJB622 Defender Technical Discussions 16 April 15th, 2009 09:01 AM
Headlight insurance for around $20. (USD) LenB Smaller Projects 7 October 9th, 2008 12:59 AM
Headlight Switch Issue, any ideas? januconn92 Defender Technical Discussions 1 July 24th, 2005 11:53 AM
