headlight acting weird - Defender Source
Old August 10th, 2011, 06:53 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
hey guys hope you get used to all these questions!
heres my problem when i turn on the headlights one headlight goes on, the other doesnt. now if i turn the brights on they both work. i assumed it was a a blown bulb, but it isnt. what could it be? sorry if this is a stupid question i am new to defenders and i am learning on how to work on this truck myself
Old August 10th, 2011, 07:47 PM
defeyago's Avatar
defeyago
Santiago
96 Defender 110 VGTdi SW County
Fuse?
SANTIAGO
97 Defender 110 Tdi SW
04 Freelander Td4 5 dr.
97 Alfa Romeo 146 TD (Sold)
95 Volvo 850 GLT Estate
94 Discovery Tdi (Webasto equipped)
Old August 10th, 2011, 07:55 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
thats what i figured and i will check tomorrow i just was confused because would each headlight be on a different fuse?
Old August 10th, 2011, 08:00 PM
defeyago's Avatar
defeyago
Santiago
Yes, they do.
SANTIAGO
Old August 10th, 2011, 08:02 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
ohhhh! ok thanks. sorry if it was a stupid question!
Old August 11th, 2011, 01:24 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Probably just a bulb. These big old 7" sealed beams have dual filiments in there, and even if your low beam filiment goes bad the high beam will still work.
Personally, I say just get a set of Hella E-code H4's and be done with it
If it's not the bulb, then get a test light and check at the bulb socket to see if you've got juice there. May just be corroded and needs a cleaning at the connector.
-Hans
My oil line fix
My 100k stopped odometer fix
Old August 11th, 2011, 07:07 AM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
-Hans
thanks i already got a replacement bulb and it still wont work i also order the hella conversion! but i will look into it more to find out if it is just a fuse or if it is what you said
Old August 11th, 2011, 07:57 AM
karlusmagnus
Karl O'Donoghue
71SiiA
I guess you took the working bulb and tried it on the non-working side?
Old August 11th, 2011, 11:55 PM
Hans's Avatar
Hans
Hans Haase
If I wasn't so busy this weekend, I'd say just come on over and we'll get it sorted out. Maybe during the week sometime if you're still having issues.
-Hans
My oil line fix
Old August 12th, 2011, 04:06 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
thank you Hans! but i got it sorted out. it was a fuse and the wire going to the fuse was loose
Old August 12th, 2011, 04:16 PM
Hans's Avatar
Hans
Hans Haase
Excellent! You're going to love the H4's BTW, a massive upgrade, particularly if you went for the (technically not DOT approved) E-Code lenses.
-Hans
My oil line fix
Old August 13th, 2011, 08:31 AM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
thanks i am puting them in today!
Old August 13th, 2011, 08:39 AM
Hans's Avatar
Hans
Hans Haase
Stock wattage? Or did you go with more powerful bulbs?
If you upped the wattage, you'll really want to put a relay in there before you melt the switch.
-Hans
My oil line fix
Old August 13th, 2011, 09:40 AM
Stock wattage ecodes are really nice.
Old August 13th, 2011, 10:24 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Where do you guys get the E-codes?
Old August 13th, 2011, 02:42 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
-Hans
well they are just the regular the D1 headlights with the flat hella lenses, i got them from roversnorth and the guy i spoke to said they are just a straight forward swap.
Old August 13th, 2011, 05:50 PM
Hans's Avatar
Hans
Hans Haase
I gotcha, never seen the D1 lights.
The E-Code Hella's I always get from Rallylights.com Great guy to deal with.
10% off if you mention D90.com too!
-Hans
My oil line fix
Old August 13th, 2011, 05:54 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
thanks but i already have this =]
Old August 13th, 2011, 05:58 PM
Hans's Avatar
Hans
Hans Haase
'tis all good. Saw somebody else asked where to get them, so figured it wouldn't hurt to post the info.
-Hans
My oil line fix
ac, ht
97 defender st - headlight retaining screw Rob Defender Technical Discussions 1 April 25th, 2005 06:22 PM
Mesh Headlight Guard NashvilleRedD90 Defender Technical Discussions 5 April 18th, 2005 03:20 PM
how to change headlight chirider Defender Technical Discussions 9 November 25th, 2004 05:59 AM
Headlight Guards RX6RCROL Wanted 5 September 17th, 2004 12:25 PM
headlight switch sub jorge Defender Technical Discussions 1 January 24th, 2004 09:10 PM
