Headlamp Upgrade to Crystal Syle Bezel - Defender Source
Old July 18th, 2013, 10:18 PM
D904evr
NAS 93 110
NAS 97 D90 ST Black
Question Headlamp Upgrade to Crystal Syle Bezel
Looking to do an upgrade from the NAS spec 97 D90 headlamp to a newer design. Light output does not need to be amazing. I would simply like to upgrade the older style lamps to a newer style (flat, crystal style) lamp without rewiring or reworking. Just a simple, buy, swap and go approach. Any leads guys!
FYI....this is going on a 97 NAS D90 would prefer a US source so I can get them in hand quickly. Not looking for ultra performance just a nice looking cleaner (newer style) upgrade.
Old July 18th, 2013, 10:24 PM
Surf jeep websites for hundreds of options.
Old July 18th, 2013, 10:29 PM
D904evr
NAS 93 110
NAS 97 D90 ST Black
So any jeep 7" light will be a drop in plug and play with the correct wiring and harness installed?
Old July 18th, 2013, 10:47 PM
If a jeep has a H4 bulb it should be the same.
Old July 19th, 2013, 09:29 AM
D904evr
NAS 93 110
NAS 97 D90 ST Black
Anything else that should be replaced while I am at it? Any tips?
Old July 19th, 2013, 09:51 AM
If you are considering running higher wattage bulbs than standard you should really look to use a headlight relay. The headlights are switched through the stalk by the steering wheel and these burn out regularly and especially if you run higher wattage bulbs.
Old July 19th, 2013, 10:10 AM
You should look at a relay regardless. The voltage loss with stock bulbs is quite bad.
upgrade advice TND90 Defender Technical Discussions 5 October 16th, 2005 08:47 AM
diameter/thread of sending units for gauge upgrade jaherring Defender Technical Discussions 3 September 29th, 2005 05:14 PM
OME upgrade advice kolvedic Defender Technical Discussions 11 August 16th, 2005 11:08 PM
FS: D-90 Parts (Bikini Top, front bumper, wagon seat back cover, shift lever bezel dzientek For Sale - Parts 5 March 16th, 2005 12:09 PM
Upgrade pushed back chrisvonc Misc. Chit-Chat 0 May 15th, 2004 11:23 AM
