Headlamp switch out - Defender Source
Old May 7th, 2012, 07:27 AM
Bryanfor311's Avatar
Bryanfor311
Bryan
Former Owner - 1994 D90 #690
Headlamp switch out
Is this a common issue or just simply random? When I removed the guard it looks like its been replaced before.
Old May 7th, 2012, 08:11 AM
LRover's Avatar
LRover
J. Michael McCaig
Common. The contacts in the switch get hot and melt the plastic. You can eliminate the problem by rewiring the circuit so the headlights get their feed through a relay and the switch just controls the relay.
Old May 7th, 2012, 10:40 AM
Bryanfor311
Bryan
Is there a way to fix the existing one? The parking lamp selection still works but when you switch it further to the headlamps everything turns back off.
Old May 7th, 2012, 10:59 PM
Bryanfor311
Bryan
Best source to purchase a new one?
Old May 7th, 2012, 11:26 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Rovers North is a good source.
Old May 8th, 2012, 04:58 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
If you wanted a cheaper alternative, you could buy an aftermarket replacement...
http://www.britishpacific.com/search.php?q=PRC3430
Eventually it will die like your current one, re-wiring the headlights through a relay would be a good investment. There are many threads on here explaining how to do it.
lamp, switch
JATE Rings, Headlamp Switch and a few other tidbits jhobbs For Sale - Parts 12 June 3rd, 2011 11:10 AM
Headlamp switch repair flynn23 Defender Technical Discussions 13 January 24th, 2009 04:13 PM
Headlamp Switch NashvilleRedD90 Defender Technical Discussions 7 February 11th, 2008 10:15 PM
