Headlamp Switch - Defender Source
Old February 10th, 2008, 10:54 PM
NashvilleRedD90's Avatar
NashvilleRedD90
Will Peters
'97 NAS D90 ST #1704 -4.6
Headlamp Switch
The 3 position (off/parking lights/parking + headlamps) headlamp switch broke on my '97 (my are hit it and broke it going down the interstate). So was looking to see how much they are and noticed there are two, one for '93-'95 and one for the '97s... I looked at a picture of them and they look exactly the same except they the newer one seems to have a newer plug on the end. And since there is $70 price difference I got to wondering if I could use the older one and just splice my old connector onto the wires.
So does anyone know if there is any difference (LR Part #'s) PRC3430 (cheaper '93-'95 switch) and AMR6104 ('97 more expensive switch) besides the plug on the end of the wires? And is there any reason why I couldn't just swap the plug for my old one?
Its not a big deal, it just seems like ~$130 for a switch seems like a but much. And if the older ~$60 one can work it would same me a little $ I could put towards other things...
'97 D90 - 4.6
'00 D2
Old February 11th, 2008, 12:05 AM
Its just the plug I believe.
Old February 11th, 2008, 12:15 AM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
My switch crapped out a couple years ago on a night drive 20 miles from the nearest payed road off in the Inyo mountains. All lights on the truck go out! I had my hellas on a separate switch so I was able to finish the drive. I replaced the switch with the $60 unit and just cut the '97 plug off and crimped on standard "bullet" connectors to work with the '95 $60 switch. I repaired the old one with epoxy and keep it as a spare.
Old February 11th, 2008, 06:59 AM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
X2, buy the 93-95 switch and cut, solder and heat shrink the 97 plug onto the new unit.
Old February 11th, 2008, 09:38 AM
NashvilleRedD90
Will Peters
Sweet...
I'll get the older version and use the older connector.
'97 D90 - 4.6
'00 D2
Old February 11th, 2008, 07:34 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
open it up, clean the dry corroded grease out of there, scrub the contacts with a little 600 grit, apply some dielectric grease and safety wire it shut. Mine is as smooth as silk again for about an hour of my time.
~Steve
Old February 11th, 2008, 07:43 PM
minorthreat
Lance
1997 LE, 1997 Black ST
If you're going to be cutting up wires you might want to put a relay in the circuit. Then you won't have to worry about the switch burning out. --And you can put in higher wattage bulbs if you choose.
Old February 11th, 2008, 10:15 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
X2 on last two posts. Personally, I would repair your existing switch AND put in the relay. Especially if you are using upgraded head lamps. Come to think of it, I did not put in a relay when I replaced my switch, so I think I will go out and preemptively put in a relay (or realistically add it to my "to do soon" list...)!
lamp, switch
Wiper motor limit switch replacement LenB Smaller Projects 5 June 7th, 2012 07:29 AM
Headlamp switch repair flynn23 Defender Technical Discussions 13 January 24th, 2009 04:13 PM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
