Headlamp replacement, advice - Defender Source
Old April 3rd, 2006, 08:54 AM
btate
Bryan Tate
d90
Update, I searched more and found the old thread...........sorry, but couldn't figure out how to delete post
My H6024 headlamps are tired, on my previous 110 I put in the replacement bulbs and lenses (thanks to the deep water at MAR) I believe I went with the Piaa.
Anyway, has anyone tried the new Sylvania bulbs or even found a reasonable HID replacement?? (if that exists)
I hoped to get really, really bright high beams and go with one set of offroad lamps on the bumper vs getting 4 up top and 2or 3 in the grill.
What's the brightest out there? I don't recall the numbers (ie 10/40) but are there any that make a big jump to high beam (street legal or not)?
Old April 3rd, 2006, 10:31 AM
SYoung
Steve
94 D-90 #8
I have HID replacements available, but they're dang near $1200 for a pair but they are the nice hi AND low beam version. The Sylvanias haven't been lasting long on my RRC, so I went with some aftermarket cheapo H4 conversion housings and just run plain Philips H4's in them.
Old April 3rd, 2006, 12:02 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
There are massively powerful H4 bulbs available out there for the housings. But the higher the rating, the shorter the lifespan. They rate the 160watt bulbs at a lifespan of only 50 hours or so.
I had used the Hella H4 bulbs (not the vision-plus) back on my 67 Bronco, and this was a major upgrade over standard halogon sealed beams. You might want to try the Hella E-code lights with the 100w/55w bulbs and see how that works for you. You can get them from rallylights.com for $80 + shipping for the pair. Since they are good E-code lenses, they are much more effficient than the crappy sealed beams we are all used to.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 3rd, 2006, 03:12 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
You can get some motorcycle lights that work--they are not DOT for trucks, but they are brighter and less expensive and quite frankly a great option. I can' t remember which ones, so I am hoping someone here can because I need to get them. I saw them at the Solihul Rally--I think whoever it was paid like $16 bucks for them. Anyone?
Old April 3rd, 2006, 03:38 PM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
www.roundeyes.com have 7" replacement headlamps for Heeps and Defenders. 100$, GREAT product, 60% brighter AT LEAST
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
ac, lamp
Jump seat cardboard replacement advice GaryBaxter Defender Technical Discussions 5 August 14th, 2007 02:57 PM
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
Advice on buying my first D90 mtbrooks Defender Technical Discussions 7 July 19th, 2005 07:48 PM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
Replacement Headlamps tuko Defender Technical Discussions 4 November 18th, 2003 09:51 PM
» Defender Registry
D 90
TommyB
D90 ROXS
MonLand
Add your Defender
