Headlamp adjustment - Defender Source
Old October 3rd, 2015, 09:40 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Headlamp adjustment
Just fitted LED headlamps on my 110, 2" lift, and 235/85 R16s. I have looked for instructions on how to adjust the lamps but am falling short. I found one post that stated to park the vehicle 4 meters from a wall and center mass of the beam should be 5 cm below the height of the headlamp. Not sure if that is supposed to be high beam or low beam. Any advice on how you guys set yours?
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
1971 109 3 Door (Sold)
Old October 3rd, 2015, 09:49 PM
Low beam.
To be honest I've never had to adjust them as they come out of the carrier and go back I the same place. If you didn't adjust the carrier mount screws you should be fine.
Old October 3rd, 2015, 09:59 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
I figured the same but the LED lamps have a slightly different fit. Just worried about blinding people. These things are bright!
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
Old October 4th, 2015, 08:06 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
It doesn't discuss LEDs but it's a great right up that may get you close.
Daniel Stern Lighting Consultancy and Supply
Old October 4th, 2015, 09:06 AM
They shouldn't fit any differently at all ... they go into the carrier exactly the same as halogen types and then the carrier mounts on the alignment screws.
what brand do you have?
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
93/94 Headlamp panel vs Series 3 headlamp panel Macker Defender Technical Discussions 3 July 27th, 2011 02:44 AM
Steering Wheel backlash adjustment Mike Finn Defender Technical Discussions 0 December 20th, 2005 12:07 PM
air meter voltage adjustment? Rod Hayward Defender Technical Discussions 4 July 24th, 2005 11:24 PM
3link center link - castor adjustment Jase Defender Technical Discussions 4 July 16th, 2005 09:24 AM
