Headgasket thickness - Defender Source
Old October 3rd, 2016, 11:04 AM
burlsube
Nick
1985 110 CSW
I just removed the head from my 200. It looks like the previous head gasket was 2 holes or 1.48mm. I plan on having the head lightly skimmed and replacing the stem seals before putting it back on.
I have read some folks suggest putting in the 3 hole just to be on the safe side. Aside from measuring I have no way of verifying that the engine warranted the 2 hole. What is the conventional wisdom on this?
Old October 3rd, 2016, 11:11 AM
Naplm00
M
Essentially measure it or 3 hole
Old October 3rd, 2016, 11:18 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
imo ..use a sled gauge and measure ... my 300tdi has a no hole or known as 4 hole thickest gasket
No Mall crawler here
Old October 3rd, 2016, 04:46 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The piston protrusion above the block should dictate the head gasket thickness, there are tables in the manuals specifying the values. This measurement should be done if you have any doubt. After the head has been skimmed, the valve recess clearance must be checked, again it is specified in the manuals, get that recess wrong, and the valve and piston will eventually touch.
Land Rover 110
Old October 3rd, 2016, 10:17 PM
If you haven't done anything to the block then use the same thickness gasket. Skimming the head doesn't affect the gasket measurements. New pistons or having the block decked yes.
------ Follow up post added October 3rd, 2016 11:20 PM ------
Ps unless it is measurably warped I would not machine the head. Clean it up and new seals
gas
URGENTLY need Headgasket for series BRAB Wanted 10 October 4th, 2015 11:42 AM
Tapping Sound after replacing headgasket waveridin1959 Defender Technical Discussions 6 April 5th, 2010 05:23 PM
rear rotor minimum thickness cdb Defender Technical Discussions 2 May 24th, 2009 11:27 AM
Handbrake shoes thickness CDNRover Defender Technical Discussions 0 April 6th, 2009 04:51 PM
Material Thickness Of This Deck??? javelinadave Defender Technical Discussions 3 March 31st, 2005 06:55 AM
