Header Rail Installation Question - Defender Source
Old December 31st, 2013, 04:48 AM
spammer
Samdford Wallace
95 RRC LWB / 86 Tithnous
I just got all the pieces together to install my soft top on my Tithonus. I was assembling everything in my garage when it dawned on me that I forgot to get bolts to mount the header rail.
Part of this was because I wasn't sure what kind of bolts the header rail I bought would need since some have different holes. The one I got has 6 holes and came from a wolf header rail. Do I need the bolts with the clamps on them (see pic)?
Or would standard bolts work for the rail? Can I pick them up from Home Depot or do I need to call rovers north?
Lastly, I bought a sand colored rail because my top is sand, but the rail is quite a bit lighter than the top. Should I paint it black? Not sure how much rail you can see once installed.
Old January 2nd, 2014, 12:00 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
The clamps are there to allow you to loosen the header bar to remove the top. You just flip them down, that loosens the header bar, allowing you to remove the top. If you don't mind busting out a ratchet every time you want to release the header bar, then go with the Home Depot hardware.
Old January 2nd, 2014, 02:18 PM
spammer
Samdford Wallace
Home Depot it is! Actually, I was surprised to find that the bolts holding on the hard top also held on to the soft top as well. They were a perfect fit. Thanks.
Old January 2nd, 2014, 03:30 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
Lets see some pics of the new top.
header, installation
Header bar / rail for soft top Naplm00 Wanted 6 February 8th, 2011 04:38 PM
Need Header Rail for 94 D90 bitz Wanted 2 May 21st, 2008 09:51 AM
Looking for header rail for NAS soft top JacB Wanted 10 March 12th, 2008 11:13 AM
ss bolt kit installation question geneseemtn Defender Technical Discussions 2 December 4th, 2005 12:28 PM
ST header bar installation TDI Guy Defender Technical Discussions 2 November 7th, 2004 07:40 PM
