Header Bar? - Defender Source
Old January 30th, 2007, 11:44 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Header Bar?
Is the header bar (Ex Mod type) in the attached photo in any way similar to the NAS bar? Will the NAS tops work with it? Can I add the snap?
Thanks!
Name:	Header Bar 002.jpg
ID:	8044   Click image for larger version
Name:	Header Bar 001.jpg
Old January 31st, 2007, 08:47 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Chris, the NAS header is more like a sidways U channel than the ex mod C channel.
Check with Badger I think they have a euro style header that will work with a nas top.
Old January 31st, 2007, 09:22 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Ron Thanks,
Gotta throw it out there thou, since you never know when you might get lucky.
Old January 31st, 2007, 10:50 AM
badgerman's Avatar
badgerman
Christopher Laws
1964 Land Badger
The style that you have on your vehicle is designed to clap down over a round filler tube with cam adjusters. Any of the tops we offer are not designed for that style. We have a euro style header bar that has the goove on the front edge and bolts to the windshield frame. It also does not have the snaps on the tips that are used on the NAS header bars. It all depends on what your plans are for a top.
Badger Coachworks
Sew on and sew forth...
Old January 31st, 2007, 01:35 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Chris,
Ultimatly I would like to go with a NAS style surrey top. With that said which direction do I head?
Old January 31st, 2007, 06:06 PM
badgerman's Avatar
badgerman
Christopher Laws
1964 Land Badger
If you are planning on using a gutter kit then you should use the Euro spec. header bar. If you are going to use a Bestop then you will need to use a NAS header bar with the snaps on the tips.
Badger Coachworks
header, header bar
Header Bar bjenk Wanted 2 April 6th, 2005 12:17 AM
header bar redrover Wanted 1 February 4th, 2005 08:44 AM
ST header bar installation TDI Guy Defender Technical Discussions 2 November 7th, 2004 07:40 PM
Header bar, yellow hinges, tailgate bar clips mspell Wanted 1 October 4th, 2004 04:20 PM
Header Bar boshea Wanted 4 June 29th, 2004 07:05 AM
