Headaches after driving? Exhaust maybe - Defender Source
Old April 7th, 2009, 08:17 PM
johnpiero
John Brancato
none
I get a pretty bad headache after driving around and I can't figure out why. There's a faint smell of something (not sulfery) but I can't make out what it is. Also, I have a fastback with a pretty drafty top. Does anyone driving at higher speeds, with an open-style D-90 have exhaust gases recirculating in a back-draft back into the cab?
Any solutions?
Thanks all!
Old April 7th, 2009, 08:48 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
where is the exhaust outlet? Pretty common problem when it comes straight out the back, and rolls over the tailgate. Also, does the exhaust tip extend past the body enough?
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 7th, 2009, 09:17 PM
johnpiero
John Brancato
none
Glad to hear that it's a common problem
Current the tail pipe exhausts at a 45 degree angle at the rear/driver-side corner. Thats about 6 inches behind the rear wheel, 3 inches INSIDE the bodywork.
But, how to I fix it?
Should I extend the tail pipe? Angle the tailpipe so that it points down?
I like the 'look' of a tailpipe exiting in front of the rear wheel, BUT I'll re-pipe it so that fuction takes precidence over looks.
something like this....
Old April 7th, 2009, 09:41 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
As an alternative, when was the last time you had your eyes checked? Eye strain causes headaches.
Old April 8th, 2009, 08:16 AM
If you want to rule out the exhaust, sleeve the tip so that it extends an inch or so outside the body and see if it improves. Then you can stay cheap with a exhaust tip, or fix properly knowing thats the problem.
When I first got my 110 I noticed a similar problem I put a seal on the back door (big gaps) and it went away.
hth
charles
Old April 8th, 2009, 08:22 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Check for leaks at both ends of the Y pipe. Mine failed the annual safety inspection due to a leak from those places.
Jimmy Buffett
Old April 8th, 2009, 09:17 AM
bitz's Avatar
bitz
Jon
NAS D90, 85 D110 CSW, 66 Dormobile
Mine is from my wifes voice in my head saying "I CAN'T BELIEVE YOU BOUGHT ANOTHER ONE OF THOSE THINGS!"
ac, exhaust, vin
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
Wow, more exhaust woes. Hans Misc. Chit-Chat 14 May 27th, 2005 02:08 PM
NRP COMPLETE Exhaust for '97 OBDII D90 dmarchand For Sale - Parts 9 September 30th, 2004 09:07 AM
The sweet smell of exhaust!! bd90 Defender Technical Discussions 2 February 1st, 2004 07:46 AM
