Head light switch repair - Is this 4 real? - Defender Source
Old September 22nd, 2004, 05:56 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
The holding nut for my headlight switch has come off again. This is the switch on the lft side of the wheel.
To really tighten the nut correctly - do I really have to unscrew the 4 screw holding the housing on the bottom half of the steering wheel column, take that off and then fix my problem?
On the positive side, the non functional lights keep my wife out of the vehicle.
Old September 22nd, 2004, 07:43 PM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
just to remove the bottom half of the plastic column, yes. It's not that big a deal. Be happy you haven't burned out the switch like most of us
Old September 23rd, 2004, 12:15 AM
paulb's Avatar
paulb
Paul / Boultbee
and still I smile and am glad for these wheeellsss..
Old September 23rd, 2004, 11:00 AM
pendy's Avatar
pendy
jim pendleton
89'd90
legend in my own mind
Old January 21st, 2008, 07:23 PM
is the headlight switch a bitch to replace or just expensive?
Old January 21st, 2008, 07:50 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Less than $50 if I remember. It's a simple plug in unless someone rewired it years ago (someone at the old Off Road Shop), so last time I was splicing and soldering to get everything to work.
Old January 21st, 2008, 10:33 PM
Neither
Old January 22nd, 2008, 09:14 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Just think, those four screws are the only thing preventing someone from stealing your truck.
Secretly I think Jim C. is starting up his Russian d-90 import business...
Old January 22nd, 2008, 10:02 AM
I wish, there's a beautiful oslo blue TD5 in my parking lot, all covered with ARB stuff.
Old January 23rd, 2008, 08:10 AM
rovertrader's Avatar
rovertrader
Dale
And to think, only four screws between you and.............
Old January 23rd, 2008, 09:58 AM
and this!
Name:	DSCF1214 - Resized.jpg
Old March 17th, 2010, 02:53 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
This will sound dumb and probably a little obvious, but just to save someone the trouble.
I replaced my headlight switch yesterday and after putting everything back together I found out the steering wheel was rubbing on the plastic shroud around the steering column. Turns out if you tighten the two longer screws on the bottom half of the plastic shroud near the sterering wheel it compresses the plastic and makes it rub on the steering wheel. Just back off the screw a little bit and no more rubbing.
ht, switch
little plastic thin piece that is glued down to cover the light near the heat switch d90guyinla Wanted 10 February 5th, 2013 05:01 PM
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
Main light switch jchan88 Defender Technical Discussions 3 November 13th, 2005 09:43 PM
Dash, Running & Head light PROBLEM ! Weldon Defender Technical Discussions 5 November 9th, 2005 02:04 PM
