Head Lamp issues - Defender Source
Old September 28th, 2004, 04:10 PM
Clarson1359
Carl Larson
Head Lamp issues
I was driving home from work when I noticed that my headlight indicator light is out... Then I realised that my headlights were also out, not a big deal as it was early afternoon.
The Situation:
My parking lights still work... along with my taillights but,
when i put the lever to the on position all indicators go out, and the headlights don't turn on. I checked ALL the fuses and was wondering if this is a normal Lucas demon... or just another quirk of my defender. Oh it is a 1994.
Any help would be great
Carl Larson
Old September 28th, 2004, 04:25 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Ah yes. This happend to me in the dead of night out in BFE. Anyway, your headlight switch is probably to blame. Its pretty common on D90s. Over time heat warps the plastic mount that houses the contact from the headlamp. As a result the contact recesses into the plastic mount, which leaves the circuit open.
I'd recommend just replacing the switch. Give George at Rovers Down South a call and order one.
DJ
PS Oh I forgot to mention. While you wait for the new switch just cut the three wires, closest to the switch, off and close the circuit by crimping/soldering the three together. This tempory fix will allow you to merely unplug the quick disconnect when you need to turn you lights off or visa-versa.
lamp
relay for head lamp switch LenB Defender Technical Discussions 0 August 28th, 2008 12:02 AM
License Plate LED Lamp & Rear Fog Lamp Install LenB Smaller Projects 24 December 16th, 2007 08:54 PM
Orange Check Engine Lamp Scoop Defender Technical Discussions 9 March 12th, 2006 07:51 AM
