Head Lamp Alignment - Defender Source
Old August 28th, 2012, 11:32 PM
Grover's Avatar
Grover
Question Head Lamp Alignment
Does anyone know the head lamp alignment dimensions "A" and "B" in the enclosed pic?
Cheers...
Old August 29th, 2012, 06:36 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Here is a link I found:
VISUAL HEADLIGHT AIMING PROCEDURE
INTRODUCTION: It is of utmost importance that your vehicle's lighting system be aimed properly in order for it to perform its best. Lights that are aimed incorrectly will not only perform poorly but may also offend oncoming traffic. When replacing bulbs, it is a good idea to verify that your lights are properly aimed. Slight variances in filament position can translate to large variances in beam pattern. The following procedure does not require special aiming equipment and ensures proper aim.
STEP 1: Find a flat level surface adjacent to a vertical white wall where the car can be parked (a garage door is an ideal location at home). Pull the car straight up to the wall as close as possible and draw a vertical line on the wall corresponding to the centerline of the vehicle (this can be done most precisely by using a yardstick and extending it from the hood ornament or badge to the wall). Pull the car straight back until the headlights are 25 feet from the wall.
STEP 2: Make the following two measurements:
Measurement A: From the ground to the geometric center of one of the headlight lenses
Measurement B: From one of the low beam headlights to the vehicle centerline. (Also measure from high beam center to vehicle centerline for 4 headlight systems) Note these measurements.
STEP3:
(A) Two Headlamp Systems:
Draw one horizontal line on the wall at a height exactly 2 inches lower than Measurement A made
in Step 2. On the line, make vertical marks both to the right and left of the vehicle centerline mark
at the distance of Measurement B from the vehicle centerline vertical line.
(B) Four Headlamp Systems:
Draw two horizontal lines on the wall, one at the height measured from the ground to center of the
headlight and one at a height exactly 2 inches lower than the measurement from the ground to
the geometric center of the headlight made in Step 2. Make vertical marks for the low beam on
the lower line and vertical marks on the upper line for the high beam as in Part (A) above (the
high beam marks are made at a distance corresponding to the high beam measurement made in
Step 2).
STEP4:
Turn the headlights on and adjust the vertical aim of the headlights so that the top horizontal cutoff of each of the beams is located along the horizontal line drawn on the wall. Adjust the horizontal aim of the low beam headlights so that the point at which the top cutoff of the beam begins to slope upwards is located at the vertical marks made in Step 3 (A).
Adjust the low beams as in (A) above. Adjust the high beams so that the center of the illuminated region is located at the cross formed by the upper horizontal line and the vertical marks made in Step 3 (B) above.
File Type: pdf HID-VISUAL-HEADLIGHT-AIMING-PROCEDURE.pdf (32.7 KB, 38 views)
Land Rover 110
alignment, lamp
left head lamp cover (used) rd10014 Wanted 8 May 17th, 2012 03:13 PM
relay for head lamp switch LenB Defender Technical Discussions 0 August 28th, 2008 12:02 AM
License Plate LED Lamp & Rear Fog Lamp Install LenB Smaller Projects 24 December 16th, 2007 08:54 PM
Head Lamp issues Clarson1359 Defender Technical Discussions 1 September 28th, 2004 04:25 PM
