Head gaskets?? - Defender Source
Old May 10th, 2015, 01:05 PM
Etienne's Avatar
Etienne
Etienne
Tdi 2500 diesel Defender 1985
Head gaskets??
Hi, new here but need help. I own a 1985 2.5 turbo diesel 110. The head gasket popped so it was taken apart to redo the head. It turned out the gasket had corroded though between no 2 & 3 pistons. The gasket I removed has no 432830 stamped on and measures 2mm with a vernier. I live in South Africa and can locate only head gasket up to 1.6mm 3 hole. I think the head had been skimmed before. What happens if I fit the 1.6mm. Will the valves hit the pistons? Any help??please.
Name:	gasket 3 hole.jpg
Old May 10th, 2015, 01:16 PM
You need to measure the piston stick put yo choose the head gasket per the manual. You can also check in the manual if the valve recess is within spec.
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
If someone fitted a 200TDI, it depends on how much was cut off the head.
If you have a 2.5 TD non TDI no chance.
RDavisinVA
gas, gaskets, head gaskets
Gosh darn head gaskets o2batsea Defender Technical Discussions 6 June 3rd, 2011 10:06 PM
3.9 motor w low miles & head gaskets RoverDude For Sale - Parts 0 May 4th, 2011 04:42 PM
Anyone done the head gaskets on a Disco II? Turbofan Defender Technical Discussions 3 June 18th, 2010 06:25 PM
head gaskets or screw it? huck1974 Misc. Chit-Chat 1 May 4th, 2007 09:16 AM
changed cam, all gaskets and now it won't run vesparover Defender Technical Discussions 4 July 24th, 2005 09:56 PM
