Head gasket replacement checklist - Defender Source
Old January 27th, 2016, 08:54 PM
jperakis
James Perakis
94 ST
Used the awesome Google search page (from josh) and found a ton of info on the topic of head gasket replacement.
I bought the composit kit with head bolts from AB and it arrived today.
Tomorrow the heavy work begins and I'm I just to confirm what things I need to look out for.
Sounds like having the heads skimmed should be done, but what else?
I'm not looking to overhaul everything and make this a bigger project than it has to, but if there are things that should be done, I plan on making the most of this project.
remember two things...
Old January 27th, 2016, 09:02 PM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
what engine? skim, oil seals, retainers/springs were on my list last summer. make sure you use an angle gauge when you tighten everything down. l
Old January 27th, 2016, 09:10 PM
jperakis
James Perakis
94 ST
Stock 3.9 v8 from my 94 NAS
Old January 27th, 2016, 09:12 PM
I have the heads hot tanked (its more of a washing machine than a tank), a valve job done, new guide seals installed, springs shimmed as necessary, and the heads skimmed as required to be perfectly flat. Not sure what retail $ is but my b2b price is $160 cash for a pair of rover v8 heads.
Old January 28th, 2016, 12:17 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
That's a righteous price.
Old January 28th, 2016, 12:22 AM
jperakis
James Perakis
94 ST
Pardon my ignorance but as this is my first rodeo on this repair, can a single machine/engine shop typically handle all of that?
Old January 28th, 2016, 12:29 AM
Yup. That's what they do.
Old January 28th, 2016, 09:25 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
That is a good price. I paid $350 for the pair two months ago from a well regarded shop in Tampa. They also pressure tested.
ac, gas
200 Tdi Head Gasket, Can the head be milled? GM13 Defender Technical Discussions 17 October 5th, 2015 09:26 AM
Sanity check - smoke from coolant port on head = head gasket failure ontheway Defender Technical Discussions 16 September 18th, 2015 05:00 PM
Buying Checklist - '97 D90 cltmatters Defender Technical Discussions 4 December 3rd, 2012 07:56 PM
Head Gasket Replacement Help Jon_Winningham Defender Technical Discussions 1 February 20th, 2007 02:15 PM
60K Service Cost and Checklist? boshea Defender Technical Discussions 12 February 26th, 2004 11:34 AM
» Defender Registry
CTX
4RF RDS
Flossie
nasdfndr
Add your Defender
