head gasket job - Defender Source
Old November 22nd, 2009, 09:22 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
head gasket job
So I was getting some crazy pressure in my coolant not too long ago. The truck would sit for 3 days and I would take off the cap to the overflow tank and it would have loads of pressure.
I would see coolant lost when I would take off the radiator plug, but still see coolant in the expansion tank.
So Andy, Eric, Jarek and I did swapped out head gaskets Saturday. I also pick up some cheap refurbished heads, Ford injectors (since I was in there), and put in those ceramic manifolds. It looks so pretty and new!
So I drive it home and notice 2 things:
A: new injectors are nice and smooth but I think they are killing my MPGs even more.
B: I thought the temp would run a lot cooler seeing as no more exhaust gasses were leaking into the coolant, But the temp was right around 195-197 and that is with a new 4 core radiator. Should the temp be lower or does this seem right? I also notice now after I ran it for a good hour that I would get out of the truck after shutting it down and check the hoses and pressure. There was no pressure at all from the expansion tank and the top radiator hose was soft, but still hot, so it was cycling, but I would thing it would be a bit stiffer.
Next: replace crappy black expansion tank with DI clear tank, because I suspect that might be giving me some trouble too.
ID:	23176   Click image for larger version
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old November 22nd, 2009, 09:45 PM
It should have some pressure. Maybe the disco I tank cap is shot or you have some other leak in the system. I have a deep suspecion of those disco tanks and caps.
Old November 22nd, 2009, 10:21 PM
ini88's Avatar
ini88
Daniel Marcello
no, I have the defender black expansion tank. I heard those were crap and to replace them with the disco tanks.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old November 22nd, 2009, 11:38 PM
You should have a metal tank. Not plastic. 1997s had the "disco" plastic tank.
Old November 23rd, 2009, 12:52 AM
bjf's Avatar
bjf
barry f
94 ST #395
sweet garage.
Old November 23rd, 2009, 03:06 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
My 97 has the metal tank. Disco black tanks are crap, they split (i've had 2 go). Disco clear tanks are much better. What is wrong with the Defender metal tank?
Old November 23rd, 2009, 06:00 AM
What thermostat are you running, i think stock for some crazy reason is 195. Did you reuse the head bolts? Why use "cheap refurbished heads"?
I am running those ford injectors also in my Classic with a bigger cam, I am getting 10-12 to the gallon and I think the oil smells like fuel. I expected the fuel mileage to decrease with the cam but before I was getting 15-16 to the gallon.
Old November 23rd, 2009, 08:39 AM
Friend, a hot radiator should have about 14-16 psi. If you open the expansion tank while hot you may find yourself swimming in glycol. I should think that there would be some pressure, but not zero pressure.
190 is not too hot. The engine needs to be somewhere lower than the boiling point of water because, clearly, boiling water cannot absorb more heat. That's why your coolant system is under pressure, as the pressure raises the boiling point above 212 degrees F, allowing for more heat to dissipate into the coolant. It also needs to be above 160-ish so as to reduce the buildup of sludge and varnish from the oil mist present in the crankcase.
You don't say whether you installed a new thermostat, but if you did not, I would recommend it. If the coolant is circulating without the "choke" of the thermostat it might give you readings that are not within normal expectations.
Old November 23rd, 2009, 01:38 PM
ini88's Avatar
ini88
Daniel Marcello
Well i went out last night around 12am because i was bored. I checked it out and some of the hose clamps were a bit loose, because i think I just missed them. So I tightened them down good. Replaced the factory black metal Defender tank with the clear Disco tank (the good one) and filled that up. I had some suspicion that the black defender tank wasn't holding pressure well or maybe the cap was messed up. So i switched it out.
Phillip, thermostat is relatively new, I think it was the 180 one. once the temp hits 200 on the gauge I see the floor gates open and it drops down to 180 fast, then as is cycles it around the 197 range.
I used new bolts obviously and i picked up the refurb heads because they were cheap and had a valve job and were cleaned up and skimmed and flat. I would rather do that then have the down time inspecting my heads to find out they are warped or something. plus the sludge build up was hilarious. I had to dig in there to find the head bolts to undo them! I have seen a bunch of other heads and they looked very clean to mine. Mine looked like someone just poured a bunch of mud in them.
I need to take it for a spin tonight to see how it goes.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old November 23rd, 2009, 01:40 PM
Did you use composite gaskets with the new heads?
Old November 23rd, 2009, 01:53 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Those metal screw clams always seem to leak on me, so I doubt you missed them. Every time I have to replace a hose, I plan on using a double-ear clamp that gets crimped on instead of those screw clamps.
-Hans
My oil line fix
My 100k stopped odometer fix
Old November 23rd, 2009, 02:09 PM
? Must be a V8 thing. Though my RRC did not have that problem. It isn't uncommon to have to re-tighten a few after the initial clamp on a new hose. Having to deal with crimped stuff would be annoying in a road or trail side situation.
-Hans
Old November 23rd, 2009, 02:19 PM
"Having to deal with crimped stuff would be annoying in a road or trail side situation."
I hate those F'in things. My lotus has them and I wanted to shoot them.
Old November 23rd, 2009, 02:30 PM
ini88's Avatar
ini88
Daniel Marcello
yup, Erling composite with new bolts. I think I need to take it for a spin again to see how it goes. with the new clear tank I can at least see if im loosing coolant easier.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old November 23rd, 2009, 02:37 PM
Dan
Wouldn't be a bad idea to check the rad for blocked areas using an IR thermometer. Also make sure the system is bled correctly. If all is well the gauge should be where it was before you started having problems.
Old November 23rd, 2009, 02:59 PM
interesting, that you are running the 180 thermostat and running that hot, my truck can get to 200, I attribute it primarily to the fan clutch and I am pretty sure it needs headgaskets. I am running the same in my classic with a new three core rad and top end and it wont budge past 180, of course it isnt summer time so the verdict is still out.
Originally Posted by Ren Ching
Dan
I think he has a new radiator.
I am interested to hear more from the guys running the ford injectors. I am considering going back with stock.
Old November 23rd, 2009, 04:23 PM
Hans's Avatar
Hans
Hans Haase
Oh, I agree totally. Serious pain to work with them. But I've almost never had one leak, and it's almost invariably my own fault when they do. I keep the screw clamps as spares for quick repairs, but I'm done using them for permanent fixes.
-Hans
My oil line fix
Old November 23rd, 2009, 04:43 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Dan, if you had that much sludge, I would drop the oil pan one day as well and clean that out as well..
Legend in My Own Mind.
Old November 23rd, 2009, 04:59 PM
-Hans
I want to replace every one I see with screw types so I guess we are opposites on this one.
Old November 23rd, 2009, 05:52 PM
Hans's Avatar
Hans
Hans Haase
Well, it's not like I've ever been accused of being sane and normal. I acknowledge the fact I'm the oddball here.
-Hans
My oil line fix
gas
D90 head gasket lead--which one? Davis Defender Technical Discussions 6 April 1st, 2005 11:52 PM
Anyone done their own head gasket? vesparover Defender Technical Discussions 16 October 9th, 2004 10:34 PM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 04:47 PM
