head gasket job - Page 2 - Defender Source
Old November 23rd, 2009, 08:34 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Originally Posted by TDI Guy
Dan, if you had that much sludge, I would drop the oil pan one day as well and clean that out as well..
Yeah im going to drop the pan this weekend and clean out the rest. i should take a photo of the old heads and show you how bad they were.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old November 23rd, 2009, 08:44 PM
Use AWAB hose clamps from Jamestown Distributors.
Old November 23rd, 2009, 09:47 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Originally Posted by rover4x4
I am interested to hear more from the guys running the ford injectors. I am considering going back with stock.
Didn't see this part earlier. I'm using stock ford injectors, not the performance models. Between that and the mallory distributor I gained about 2.5mpg improvement. I forget the exact part numbers I'm running though, a LOT of the ford injetors fit.
-Hans
My oil line fix
My 100k stopped odometer fix
Old November 23rd, 2009, 09:52 PM
Grover's Avatar
Grover
-Hans
So what is your average mpg now?
Cheers...
Old November 23rd, 2009, 11:54 PM
ini88's Avatar
ini88
Daniel Marcello
Ran it tongiht and the guage was right in the middle. 200. This truck should be running colder than a witches tit! What gives.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old November 23rd, 2009, 11:59 PM
describe the procedure used for filling the cooling system.
Old November 24th, 2009, 12:21 AM
ini88's Avatar
ini88
Daniel Marcello
Rad, heater pipe, expansion tank.
I swear im switching to deisel. I try to be nice to the engine and get him new gaskets, heads and injectors and he wants to act all hot. im just going to have to swap him out for a nice new 300tdi.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old November 24th, 2009, 12:30 AM
Hans's Avatar
Hans
Hans Haase
Cheers...
Went from 10.5 to 13mpg. Though we're back to the ethanol enriched around here again, so that knocked me back to 12mpg for the winter.
In more practical terms, I went from 150 miles per tank to 185 or so. This is with a SW top and huge winch bumper + winch.
-Hans
My oil line fix
Old November 24th, 2009, 07:47 AM
Maybe he's a she, and doesn't like being called a he?
Old November 24th, 2009, 07:50 AM
so if you check those 3 locations while cold all are still filled to the top? did you burp the top rad hose?
Old November 24th, 2009, 07:46 PM
Thats interesting on the injectors.
Old November 25th, 2009, 02:03 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Hmm well that is a lot of sludge biuld of you got there, thats indicative of years of neglect (bad oil / infrequent oil changes?) Could it be a porous block due to the over heating? Did you check to make sure no sleeves dropped or move around? Probably could use a good oil flush with some type of circulating cleaner.
Robert Deniro
Old November 25th, 2009, 02:39 PM
ini88's Avatar
ini88
Daniel Marcello
going outside now to drop the slump and see how bad the caked up sludge is.
then flush the radiator, run a hose through it and flush it again, then park in on an incline and fill it up. I know remember that when we filled the radiator back up the front wheels were completely deflated so we could get into the engine bay easier. So I hope I just have an air bubble at the back of the engine.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old December 1st, 2009, 04:09 PM
ini88's Avatar
ini88
Daniel Marcello
Update: Changed oil and dropped the slump to find it really clean! Flushed coolant and filled it on a big incline so that coolant could move to the back of the engine.
Now I noticed something when driving back 4 hours to NY. On a long downhill on the highway I would pop the truck into neutral for 300-500 yard so it was at 1700rpm idle. Then as the decent would start to flatten out I would rev it up once to 2500ish and slip it into 5th gear and would notice instantly that the temp would go from 205ish to 190 or below!
Now is it doing this because the engine is cooling itself at idle speed while 75mph air is going through the radiator? Or is my fan catching when I pop it into 5th and instantly cooling it down? Water pump spinning faster?
The drop happens so fast that it really can't be just the truck running at idle for 500 yards, because I would see it gradually go down. this is more like POP into 5th and BAM! 10-20 degrees cooler.
Thanks again for the help you guys & sorry to dig this back up.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old December 1st, 2009, 10:40 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
May be a long shot but are you sure your gauge is well grounded?
Old December 1st, 2009, 10:56 PM
ini88's Avatar
ini88
Daniel Marcello
1 year old VDO guage and new sending unit. should be fine.
Edit: oh grounded!? hmmmm I will check on that! might not be.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old December 2nd, 2009, 01:54 AM
D90user's Avatar
D90user
steve
I was having some really weird things happen to my temp a while back. I finally noticed that when I turned the headlights on it got hotter. It ended up being the stock ground.
Probably wont be, but it is an easy fix.
gas
D90 head gasket lead--which one? Davis Defender Technical Discussions 6 April 1st, 2005 11:52 PM
Anyone done their own head gasket? vesparover Defender Technical Discussions 16 October 9th, 2004 10:34 PM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 04:47 PM
