head gasket blocking dip stick. - Defender Source
Old November 1st, 2007, 05:34 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Installed my new head gaskets. After bolting the heads, rockers and manifolds on I noticed that the gasket is partially blocking the sleeve for the dip stick. The gasket did not have the word "top" anywhere on it but I asked two people who said to install them with the side with metal on it towards the block. If they are upside down is it ok to leave them and just cut away the gasket covering the dipstick?
Old November 1st, 2007, 09:45 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
Well, it is a little to late to take them off hahahahaha. I would probably get another set before I chanced it with them on the wrong way. Could be blocking oil or coolant passages, take that back it is blocking oil and coolant passages...
Old November 2nd, 2007, 01:44 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Yeah that;s what's messed up.. everything lined up perfectly. Back to dissasembling..
Old November 2nd, 2007, 08:53 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Do you think I could take them off and flip them around and reuse them or do I need to get new ones? I have not started the engine since installing them?
Old November 2nd, 2007, 09:13 AM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
Before you do I had the same issue and noticed it before I tightened everything down. Flipped them everywhichway and confirmed placement, still blocked dipstick, so I just cut out what wasn't needed and finished. No problems since. I'm not sure but I think some of the Buick gaskets are just slightly different. Obviously if you are concerned and doub your work then remove and refit, but your new head bolts are now stretched and v expensive. Don't take my word for it, just my experience.
Old November 2nd, 2007, 09:19 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
So every way you turned it the stick was still blocked? In a way that's good to hear. Do you remember which side you put down.. side with the metal on it?
Old November 2nd, 2007, 09:27 AM
rgrrvr's Avatar
rgrrvr
1995 D90
Dont recall, I could look but the truck is not here. Definately fipped them, definately had to go the way it was blocked, definately cut them, definately not having issues. Good Luck
gas
D90 head gasket lead--which one? Davis Defender Technical Discussions 6 April 1st, 2005 11:52 PM
Head Gasket Kit? Quimbola Defender Technical Discussions 9 November 5th, 2004 11:24 PM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 04:47 PM
