Head Gasket Basics - Defender Source
Old May 2nd, 2016, 07:52 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Head Gasket Basics
Found this write up helpful to read through and thought I'd pass it along.
http://www.enginebuildermag.com/2009...skets-to-fail/
Old May 4th, 2016, 03:49 PM
cbfritz_03
Carmen
none
Thank you. I've been doing lots (and lots) of reading. Started my first top end rebuild on the V8....urgh, so nasty...
Car Camping Collective founding member - Badge #88 ...with 4 whole fried chickens and a coke.
Old May 4th, 2016, 03:52 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Maybe not enough reading... unless you're replacing those push rods, they should have been put in order on a sheet of cardboard
Old May 4th, 2016, 04:02 PM
cbfritz_03
Carmen
none
A babe in the wood that's for sure. Aren't they all the same length? The valve springs will be replaced but not the pushrods. I'm hoping it will be less scary/mysterious on the next one. I have friends with experience on speed dial. Wish me luck. I'm gonna need it...
Old May 4th, 2016, 05:08 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
There is loads of good advice in various threads on this board (including placing the pushrods in a piece of cardboard that diagrams how/where they go back in). The one thing I didn't read but wish I had before I rebuilt my top end this winter was to pressure wash and degrease everything before disassembly. So much of my work was cleaning years of gunk from the outside of everything.
Old May 4th, 2016, 06:06 PM
It doesn't matter what order they are in. Of the thousands of head gasket jobs that have been done on Rover V8's, how many do you think were put back in order? Sure, the 'right' way is to put them back in order, but in reality it doesn't matter. I've never put them back in order.
Old May 4th, 2016, 06:13 PM
Naplm00
Matthew
Just buy a pushrod length checker on amazon, it's an adjustable pushrod you can use to measure the proper needed length and replace if necessary. New pushrods are available in all types from Summit or jegs
Old May 4th, 2016, 07:12 PM
cbfritz_03
Carmen
none
Will do. I had read and seen vid on the cardboard and in order stuff a long time ago but because the rods don't show any variance or significant wear, I didn't worry about it. To be honest I have to control myself and not pull the whole thing. It doesn't need it and ran great. Once I took the valve covers off I decided to do this...clean it up, replace upper and lower gaskets, hoses, the fan clutch, a few sensors, rebuild the oil pump...etc. I've only had her for a little while....it's maintenance
Old May 4th, 2016, 07:17 PM
Plan to do the timing chain as a minimum as it will need it. That is not a well loved engine. Also check the cam is not worn.
Old May 4th, 2016, 07:31 PM
cbfritz_03
Carmen
none
I'm doing the timing chain too. Can you think of anything else...while I'm in there?
Old May 4th, 2016, 10:56 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Probably why yours runs hot!
Old May 4th, 2016, 11:07 PM
You replacing the cam as well? If so that opens up more parts to consider
Old May 5th, 2016, 06:57 AM
No, thats's because I didn't do the Discomike 90k service.
Old May 5th, 2016, 07:14 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I just sent him your cell #, he should be calling you shortly!
Rent my
Old May 5th, 2016, 04:37 PM
cbfritz_03
Carmen
none
Still digging...and yes, more parts. Am thinking a Crower cam...
Old May 6th, 2016, 01:34 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I put in an RP4 cam when I did my top end. Pretty happy with it. Think it was 200 something bucks RPI engineering. I would also mention that you should check the tappets to make sure they aren't dished or worn. While i'm no expert at all, I think you're supposed to change the tappets all together if you're changing the cam.
That poor engine.. amazing to me how many people think an oil change is just an automotive rumor and not scheduled maintenance.
Old May 6th, 2016, 01:37 PM
Yes you have to do the tappets along with the cam. And based on the condition of that rocker shaft, I would say pull the engine and do everything.
you can check/replace the bottom end shells and the rear main. The engine is much easier to work on with it out of the car, it will save you alot of time to have it out.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old May 6th, 2016, 01:40 PM
This is going to turn into a huge project if you go with the 'while I'm in there" approach. Its a Rover V8, everything is probably worn out but functions fine.
Old May 6th, 2016, 01:50 PM
functions fine as in under powered due to the wiped cam lobes, low oil pressure due to the worn oil pump parts, wacky retarded timing due to the stretched timing chain, and misfires due to the leaking rings and valves?
Not to mention what happens when one piece of that sludge breaks loose and plugs an oilway.
Yes it is a big project to pull the engine but when it looks like that on the inside, it is really the only way worth doing.
Did that job once with the engine in the car and will never do it that way again. Or so I say, now, sitting here at my keyboard...
Present:
1987 RRC- "Chewy 2"
Past:
Old May 6th, 2016, 01:56 PM
jperakis
James Perakis
94 ST
Ain't that the truth.
I went from 'oh I'll just replace the headgasket' to 100 real quick.
remember two things...
200 Tdi Head Gasket, Can the head be milled? GM13 Defender Technical Discussions 17 October 5th, 2015 09:26 AM
Sanity check - smoke from coolant port on head = head gasket failure ontheway Defender Technical Discussions 16 September 18th, 2015 05:00 PM
4.0 V8 engine parts for sale (starter motor, upper gasket set, lower gasket set) bagocheetohs For Sale - Parts 7 August 11th, 2015 07:12 PM
Defender and sankey driving basics Overlander Defender Technical Discussions 14 March 17th, 2015 12:31 PM
» Defender Registry
Honcho
bennett
Stormy
Bozman
Add your Defender
