head gasket 300 tdi, - Defender Source
Old May 24th, 2014, 10:58 AM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
Question, what is the difference between a two hole vs a three hole head gasket? Can I use a two hole in place of a three hole?
Old May 24th, 2014, 11:13 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
.10 MM
I wouldn't...you might be able to
http://www.roversnorth.com/ProductDe...210&type=0&eq=
http://www.roversnorth.com/ProductDe...220&type=0&eq=
Old May 24th, 2014, 11:17 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
It's the thickness of the gasket. 1 hole is the thinnest, working up past 2 and 3 before arriving at no holes being the thickest. You are supposed to measure the highest protruding cylinder with the head off, and then once you have found the highest one, you select your gasket:
Protrusion 0.50 to 0.60 mm - select gasket with 1 identification hole.
Protrusion 0.61 to 0.70 mm - select gasket with 2 identification holes.
Protrusion 0.71 to 0.80 mm - select gasket with 3 identification holes.
Protrusion 0.81 to 0.90 mm - select gasket with 0 identification holes.
Old May 24th, 2014, 11:27 PM
CavemanDiesel
Eric Smirh
1985 D90
Thanks for the info,
Looks like my 300 TDi head gasket blew again cdb Defender Technical Discussions 6 July 2nd, 2008 08:27 PM
Head Gasket Kit? Quimbola Defender Technical Discussions 9 November 5th, 2004 11:24 PM
Anyone done their own head gasket? vesparover Defender Technical Discussions 16 October 9th, 2004 10:34 PM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 04:47 PM
