Head Bolts. Sealant? or no sealant? - Defender Source
Old January 18th, 2005, 10:27 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
No book, and it was too damned cold and I forgot to check something when I had the heads off. Figured I would ask before it's too late to correct a wrong situation.
Do the head bolts on a 3.9 enter into the cooling jacket and need sealant? Or are they plugged holes at the bottom and don't need sealant? The old ones look like they didn't have any sealant on them, but I figured I would ask either way.
Oh, and does anybody know what size socket I need for the valve cover bolts? Damned 12pt bolts, I need a new socket, but it's 6 degrees out right now and I don't feel like checking at the moment.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 19th, 2005, 11:42 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Hans,
Head bolts do not need sealant...lube the threads and under the heads with light oil like ATF when assembling...make sure the bolt holes are clean and dry. Valve cove bolts are 8mm or 5/16 12pt.
Rob
bolts
ARP head stud compatibility? Hans Defender Technical Discussions 0 November 12th, 2004 10:37 PM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
