Head Bolt choices - Defender Source
Old February 19th, 2010, 08:50 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Head Bolt choices
Anyone aware of any serviceability issues with the ProLine head bolts vs OEM?
$59 vs $95
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 19th, 2010, 09:57 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Not sure what you mean by serviceability as they are use-once stretch bolts, but I have used them with fine results. The most important thing is to make sure the threads are very smooth so that your torque is consistent--if they seem rough or uneven at all, I would run them through a thread die to smooth them out.
Old February 19th, 2010, 10:07 AM
Antichrist's Avatar
Antichrist
Tom Rowe
I meant do they perform (install/last/not come lose) as well as the OEM.
------ Follow up post added February 19th, 2010 10:23 AM ------
The reason I'm asking is that the head gaskets on my Disco are blown and with 260k on the engine I thought I'd take the 95k mile engine that was in my D90 and put it in my Disco. I thought I'd go ahead and replace the head gaskets while I was switching over all the front cover parts from my Disco that I need to swap to my D90 V8.
(sorry for the additional post, my message edit time has expired)
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 19th, 2010, 03:07 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Yes, very similar on my two trucks (DII and D90). I noticed no difference other than the price.
Old February 19th, 2010, 03:11 PM
Wait, what year D90? If you have a 1993-95, you have metal gaskets.
Old February 19th, 2010, 03:13 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Just to ask, before you go through all the work, does the disco have a 3.9 or 4.0? The 4.0 and 3.9 have different length crankshafts, and oiling systems, and the front covers aren't interchangable
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 19th, 2010, 04:28 PM
Antichrist's Avatar
Antichrist
Tom Rowe
They are both 1995 3.9's.
I ordered an STC1641 head kit (metal gaskets) from TNLR, $49, and a couple of composit head gaskets for $10 each, just in case.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 19th, 2010, 05:55 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
The composite gaskets are thicker (IMHO, superior as well) but they will increase the volume a little of your combustion chamber, so if you want to retain your compression ration (1:9.35, I believe), you might consider milling the surface of the head down the incremental distance (which also trues up your head, too). If I was doing it, I would use the comp gaskets and not put in the outer row of bolts--plenty of info on this site about all that, just search if your interested.
Old February 19th, 2010, 10:59 PM
huck1974's Avatar
huck1974
shane cates
94 d90
ARP best bolts made
And hay
And I love you too
Old February 20th, 2010, 12:35 AM
Bolts are specific to the type of head gasket. I think some of the 1995 discos or maybe even all or most had composite.
Old February 20th, 2010, 01:42 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I am using arp studs on the engine I am building now--first time using them. comp gaskets.
Old February 20th, 2010, 07:22 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Yeah, that's why I ordered composit gaskets too, and am waiting till I get the heads off to make sure, before ordering bolts, but based on the number, I'm 99% sure it's composit
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 20th, 2010, 11:32 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Even if they are metal gaskets currently being used, I would still use composite on rebuild.
Old February 21st, 2010, 08:26 AM
So no one is still using the old tin gaskets?
Old February 21st, 2010, 11:32 AM
Hans's Avatar
Hans
Hans Haase
Very few people, the composites are just that much better. The oil sludge problem mostly comes from the poor seal of the tin head gaskets, combined with the extra row of head bolts that contributes to the leak.
I honestly can't think of any compelling reason to use the tin gaskets anymore.
-Hans
My oil line fix
Old February 21st, 2010, 02:35 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
or the first row of bolts...
Old February 22nd, 2010, 12:22 AM
CDeWan
Clay DeWan
5.3L beastie
The 3.9 in the 94 lasted 260+ with tin gaskets. The engine always had synthetic oil since day one. I had a water pump malfunction that did the motor in and if not for that I know the engine would still be going.
Old February 25th, 2010, 07:22 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Well, I don't know why I'm surprised, but;
The manual says engines without suffix B have tin head gaskets and 14 head bolts.
Engines with suffix B have composite gaskets and 10 head bolts.
Mine does not have suffix B and has a composite gasket and 10 head bolts (and no empty bolt holes).
Is the manual backwards? Or is it possible someone replaced the heads in the past? Will a 10 bolt head even fit a 14 bolt block?
I guess it doesn't matter really, just looking to satisfy my curiosity. I'll be using the composite head gaskets I got.
One other thing. I was thinking of plasti-gauging the big-end and main bearings while I had it on the engine stand, but the manual says if the bearings are removed new ones need to be fitted. Would that be the case even pulling the cap to use plasti-gauge, or do they mean if the shells are removed from the caps?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 25th, 2010, 11:35 AM
LRover's Avatar
LRover
J. Michael McCaig
as others have said, it's recommened to leave the outer row of head bolts out to prevent the head from warping and causing the headgasket to fail...that's what is different on the later heads...no holes. I have successsfully used non-stretch head bolts with the composite gaskets. I'm not sure when Rover changed the rod bolts but the ones on my 4.6 were the stretch type as well.
Old February 25th, 2010, 11:55 AM
Tom, you have what I would expect you to have. edit: i think a 10 bolt head will fit on a 14 bolt bolt, but I have never done that, only the other way around.
Head Bolt with Alternator Stud, Is It Needed? Grover Defender Technical Discussions 6 October 28th, 2008 12:33 PM
Head bolt torque Bowtracer Defender Technical Discussions 1 September 14th, 2005 11:22 AM
Help with head removal... Trigger Defender Technical Discussions 6 July 12th, 2005 10:56 PM
