Head Bolt choices - Page 2 - Defender Source
Old February 25th, 2010, 12:03 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Originally Posted by evilfij View Post
Tom, you have what I would expect you to have.
Are you saying the manual has the with/without suffix B backwards? Or someone changed the heads for the later type with only 10 bolts?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 25th, 2010, 12:25 PM
The 1995 discos I have seen all had composite gaskets and 10 bolts. I think that is the way they came. I am not sure about the suffix issue as I never checked block numbers I just visually inspected them.
Old February 25th, 2010, 01:55 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Tom, you have what I would expect you to have. edit: i think a 10 bolt head will fit on a 14 bolt bolt, but I have never done that, only the other way around.
I put 10 bolt head on my 14 bolt block. The bulge for the bolt hole is there, its just blanked off. I had those super early tin gaskets that are like -3mm thick
I redid mine with an Elring gasket kit from Tillary. The gaskets are composite and very nice. Came with all the bolts needed. It came with a lot of other gasket you really don't need but will come in handy down the line.
The early heads came with I think 3 or 4 extra bolt holes on each side that are gone on the newer heads. I would hesitate to put those in because they seem like if they were slightly tighter could cause the inner bolts to be looser causing a gap.
Also follow the rebuild order correctly.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 25th, 2010, 01:58 PM
ini88's Avatar
ini88
Daniel Marcello
see blanks
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 25th, 2010, 02:54 PM
Antichrist's Avatar
Antichrist
Tom Rowe
ok, gotcha. I'll try to let go of the suffix B issue...I really will, I promise.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old May 1st, 2010, 07:31 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
I need to replace my 94 3.9 head gasket pronto. SO let me understand this: I just leave out the four outer head bolts (is that 11, 12, 13 & 14?) when using composite? Don't the boltholes open in the blocks cooling system? What is the best composite kit? Is there one that contains the head bolts?
Dan
94D90 st
Head Bolt with Alternator Stud, Is It Needed? Grover Defender Technical Discussions 6 October 28th, 2008 12:33 PM
Head bolt torque Bowtracer Defender Technical Discussions 1 September 14th, 2005 11:22 AM
Help with head removal... Trigger Defender Technical Discussions 6 July 12th, 2005 10:56 PM
