HD half shafts and stub tolerances - Defender Source
Old August 10th, 2011, 10:25 PM
DD90's Avatar
DD90
DD
94 D90
Couple questions on HD shafts:
The HD axles like GBR and Rovertracks are thicker than OEM, correct?
Do these HD axles then simply slide into the stub??
Do the tolerances allow that?? Does this cause any problems with letting oil flow around??
Do you need special seals to accommodate for the increased size??
Old August 10th, 2011, 10:38 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Same size just much better materials. They slide right in,nothing else required.
Old August 10th, 2011, 10:39 PM
DD90's Avatar
DD90
DD
94 D90
What are the differences GBR to Rovertracks??
Materials and machining???
They're both same diameter???????
Old August 10th, 2011, 11:08 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
To get to the point, if you have broken axles or worried about breaking your stock components, by a set of either, install, and forget. As Kevin says, same dimensions, just better materials. Just pull stock, install HD, easy. I'm partial to Rovertracks. Keith is good people and his stuff doesn't break.
Old August 10th, 2011, 11:22 PM
DD90's Avatar
DD90
DD
94 D90
thanks guys.
Half Shafts jimmy salmon For Sale - Parts 1 February 9th, 2011 03:16 PM
hub and stub compatibility KevinNY Defender Technical Discussions 14 May 22nd, 2006 03:43 PM
