hazard switch wiring - Defender Source
Old January 8th, 2007, 04:29 PM
electrical experts needed! I have a euro spec bulkhead in my NAS 110 now, and it came with a late 90's 300tdi harness. I do know it's a high amp LHD type that came wired for A/C. I don't have my original harness anymore, and I'm trying to fit a hazard switch. I don't know exactly what harness I have, and I can't seem to find any connection on it for a hazard switch. I bought a new hazard switch from RN (part #AFU4209L) but it has male bullet prongs on it, and i have nothing to guide me on hooking it up, nor do I have any idea how the leads should connect to the male prongs on this switch. Any ideas?
Old January 9th, 2007, 03:53 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Early Tdi harness will have the hazard plug near the wiper motor cover. Later ones it is in the center dash area.
Look for a black plug with green/white, green/red, purple, etc wires coming out of it.
The euro switches go where the NAS cars have the dash illumination dimmer switch.
If you find the connector then let me know and I can give you the correct switch #.
Email:
Old January 9th, 2007, 04:09 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I have that hazard switch (lower dash section by the knee). Bought it for a project and elected not to use it. Don't have the PN but it is the black one, fits in the location Mike speaks of. Has all of the male prongs on the back. Paid $16 for it.
Let me know.
Edit:
PN ASU1009
It's a common switch for Mini's, etc.
Old January 9th, 2007, 04:17 PM
Mike,
Got an email from pendy, and he said that the plug is in the location you described right now, with a jumper to allow my signals to work. Haven't pulled the cover off so Haven't seen it, but you sound right on. Pendy told me the harness connector for it is the 8 pin type (don't know what that means yet). I bought an NAS hazard switch from RN, and after seeing it, suspect I'll be returning it shortly.
David,
I'll buy yours if it's the right part. Can you post a pic of it to confirm? I'll post a pic of my plug connector as well.
Old January 9th, 2007, 04:53 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Pic. No sweat, let me know.
Old January 10th, 2007, 08:37 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I would like to wire up the 2002 style hazzard switch to my truck which also has the same euro hazzard switch. Is it possible Mike?
Legend in My Own Mind.
Old January 10th, 2007, 08:52 AM
ECR's Avatar
ECR
That picture is the correct hazard switch for the early style, and you are right the NAS switch (square type) won't work. That Euro switch should do the trick and will plug right into your wiper motor cover and harness.
I've done a number of "NAS" to "new Euro" dash conversions, like this:
http://www.eastcoastrover.com/161.html
but never tried a "old Euro" to "new Euro" conversion of the hazard wiring. I assume it can be done no problem, but just haven't done it myself so I'm not sure what wires are on the early Euro harness, but it should be a piece of cake like it is with the "NAS" to " new Euro".
Email:
Old January 10th, 2007, 03:48 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Mike, I still have to call you about that plug for the New style Switch. I will then try to figure out the wiring I guess..
Old January 10th, 2007, 04:52 PM
ECR's Avatar
ECR
Connectors for the late model hazard switch have gone out of production (at least from my supplier).
Email:
Old January 11th, 2007, 10:43 AM
pendy's Avatar
pendy
jim pendleton
89'd90
David M's picure looks right for the connector. I'll half to double check after I'm off house arrest-surgery.
JP
legend in my own mind
Old January 11th, 2007, 10:51 AM
David, I'll send a PM.
Old January 11th, 2007, 03:34 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Mike, do you mean you can not get the plug for the 2002 and newer style switch or the NAS D-90 one?
Old January 11th, 2007, 04:11 PM
ECR's Avatar
ECR
Since LR stopped using that hazard switch (the roughly 2004 Euro spec. one) with the advent of the "new" Defender, the manufacture stopped making the connector for the 2004ish hazard switch. They still have the switch, but not the connector anymore.
Never had to try to get an NAS hazard switch connector. Doubt those can be had either nless you cut if off an existing harness.
I've got the schematic for the conversion and wiring, but weren't you going to start selling dash update kits???
I'm happy to provide folks with free info for their Rovers, but if you are going to profit from a dash update kit you'll need to do your own research (I always have to).
Email:
Old January 11th, 2007, 04:18 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
LOL.. This is for my truck only. Mine goes from euro switch to 2002 style switch shich no one really has on ths board. I might have a tip on the plug for the 2002 switch though. I will let you know if I do though. Right now, I just have my switch in there to fill the hole and the euro switch works the hazzards on my truck. I would like to get it together one day to work correctly.
As for the kits, Its just the dash parts needed. I don't get involved in electrics. Don't want to burn anyones truck to the ground.. lol For that, they are on there own.
Old January 11th, 2007, 05:10 PM
ECR's Avatar
ECR
Not to hijack this thread but...
for the dash conversion how did you solve the vent flap control issue? The new style (round knob) controls have a longer throw than the NAS vent levers and when mated to the metal sub-dash on an NAS Defender they won't close the vent flaps all the way. We had to make different arms on them to get them to seal correctly.
or does your kit retain the NAS vent flap controls?
Email:
Old January 11th, 2007, 05:25 PM
Sure wish I knew the part number for the main wiring harness ECR used for its 300tdi restorations...
I know I've asked you before Mike, I just wanted to toss out a subtle reminder, though maybe you'd have the info handy since you are in the middle of another NAS100 to 300tdi resto.
Old January 11th, 2007, 06:44 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have just installed the updated metal sub-dash to the new style. It only needs minor alterations to bolt right up to the NAS bulkhead.. Mike, why don't you guys use the Bunnel silver dash facia in your builds? It looks much better in my opinion. I have the part # if you need it.
Old January 11th, 2007, 07:13 PM
Hijack away Mike! I got my help resolved. Thanks all!
Old January 12th, 2007, 08:09 AM
ECR's Avatar
ECR
Thats a hell of a "kit" for a DIY guy. We use the new sub dash in the restos, but for folks that just wanted the updated dash and not break the bank it was easier to modify the sub dash as that means a lot less tear down on the car (therefore less $$).
As for dash color... I don't like anything bright on a dash. It tends to catch my eye too much, especially if the top was off. I'll install the other color if a customer desires it, but if they leave it up to me they get dark colors, clean and simple.
Its a personal choice.
Email:
switch, wiring
Hazard Switch Wiring CDeWan Defender Technical Discussions 0 February 18th, 2009 12:53 AM
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
Need help wiring genuine fog lamp switch and Hellas fleabus Defender Technical Discussions 1 May 21st, 2006 02:00 PM
Fuel Pump, Switch, Relay, or Wiring? bbandit Defender Technical Discussions 19 July 10th, 2005 12:08 PM
