Hazard switch problem - Defender Source
Old June 17th, 2012, 12:05 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
i took apart my dash to get to a few things. Install a head unit and mud consul, enlarge the heater inlet in the bulkhead, Dynamat and so on. While doing this the hazard switch basically fell apart as I was pulling the lower dash out so I ordered a new one, popped it in. The hazards work like they are supposed to but now when I try to use the turn signal it just flashes like I turned the hazards on. Before the switch fell apart the turn signals worked like they were supposed to. Is there a way I can bypass the hazard switch so at least my blinkers work until I figure out the problem? Any thoughts?
thanks, Jason
Old June 17th, 2012, 01:40 AM
petminded's Avatar
petminded
David
1995 Defender 90- Yellow- Soft Top
Hey Jay. Month I had a similar problem w my D90. I had removed the center- clock/cig lighter/hazard switch to see if I could fix the clock. When I ran out of time and could not reinstall it all until the next wkend I found myself driving with out turn signals all wk.
That said I would assume your theroy is correct. Somehow you can by pass the hazard switch. But how is a good question.
Old June 17th, 2012, 08:41 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Silly question but did you re-connect the two side wires on the Haz. switch?
Land Rover 110
Old June 17th, 2012, 08:55 AM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
See if this helps you out.
http://forums.lr4x4.com/index.php?showtopic=25376
Patches are for Pirates and pants, not a bulkhead and chassis!
Old June 17th, 2012, 08:59 AM
defeyago's Avatar
defeyago
Santiago
96 Defender 110 VGTdi SW County
Those are for the lamp inside the switch.
SANTIAGO
97 Defender 110 Tdi SW
04 Freelander Td4 5 dr.
97 Alfa Romeo 146 TD (Sold)
95 Volvo 850 GLT Estate
94 Discovery Tdi (Webasto equipped)
Old June 17th, 2012, 11:36 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Broadstone, that was exactly what I was looking for, thanks. I had seen that once before but could not find it again.
Old July 4th, 2012, 12:09 PM
texrover's Avatar
texrover
Jason
Originally Posted by broadstone View Post
Came across the link above while looking at this link for troubleshooting my 110 indicator issues:
http://www.land-rover-blog.co.uk/how...dicator-fault/
Jason where did you buy your new hazard switch and did you buy OEM?
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old July 4th, 2012, 01:58 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
It was an OEM, I got it from George at RDS, I think. I may have just got a bad one or something, I jumped the switch and the turn signals are working now. I put the new LEDs from Lucky8 in too, what a difference!
Old July 6th, 2012, 06:26 PM
texrover's Avatar
texrover
Jason
Anyone have a part number for the 12v relay for the indicators that go behind the fuse panel?
Napa guy drew a blank when I took my relay to the store
He's going to order a couple of options for me to look at tomorrow but wondering if someone has something definitive
I've got 15 days to get the 110 inspected and hope to get it dine this weekend if I can track down my horn and turn signal issues
2003 RR L322
1971 Series IIA
1994 D90 ST (PO)
Old July 6th, 2012, 09:52 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I think I have an extra fuse. I'm back in dallas Saturday night.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old July 8th, 2012, 12:26 PM
texrover's Avatar
texrover
Jason
Thanks Reese!
Is it the Tridon EP26?
2003 RR L322
1971 Series IIA
1994 D90 ST (PO)
Old July 8th, 2012, 06:31 PM
Reese_D90's Avatar
Reese_D90
Reese
Flasher
Here is the one I have
Name:	Photo Jul 08, 5 20 47 PM.jpg
ID:	53952   Click image for larger version
Name:	Photo Jul 08, 5 20 59 PM.jpg
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old July 8th, 2012, 10:05 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Unless the lucky 8 ones are different, the stock flasher will not work with LEDs. All the lights will flash together I believe.
I forget the right one but it's on ECRs site I believe. If not, search threads here and you'll find it.
switch
MUD UK Hazard Switch Wiring sonoronos Defender Technical Discussions 13 February 27th, 2017 02:18 PM
hazard switch wiring Overlander Defender Technical Discussions 18 January 12th, 2007 08:09 AM
Headlights - switch problem? mgrgpg Defender Technical Discussions 3 December 14th, 2005 03:42 PM
