Hazard lights work but indicators and brakes don't - Defender Source
Old September 21st, 2014, 11:54 PM
Hache
Henry Lambert
1983 Ex-MOD 90 2.5N/A
My ex-mod indicators and brake lights are playing up ie not working at all. But weirdly the hazard works.
Fuses seem ok.
Is the hazard flasher relay the same as the indicator?
Any ideas?
Old September 21st, 2014, 11:56 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Yes. Make sure the hazard connector is firmly seated.
------ Follow up post added September 21st, 2014 11:58 PM ------
What exactly is going on with brake lights? You have ignition on, step on brake pedal, and no brake lights?
Old September 21st, 2014, 11:59 PM
Hache
Henry Lambert
Yes it's the same relay?
Which connector? The one behind the dash switch? Thanks!
Old September 22nd, 2014, 12:54 AM
Hache
Henry Lambert
Exactly. No brake lights at all.
Old September 22nd, 2014, 01:39 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Might be a stupid question but have you checked your brake switch?
Old September 22nd, 2014, 03:17 AM
Exactly! Do you have power to the brake light switch on top of the master cylinder?
Old September 22nd, 2014, 11:19 AM
Hache
Henry Lambert
Stupid question, but where is that? I can see the master cylinder but not the switch
Old September 22nd, 2014, 11:49 AM
Hache
Henry Lambert
So I took out a couple if relays - the flasher and one other - blew the dust out and reconnected. Indicators and brakes are working again.
Not sure why this would work but I'll take it.
Old September 22nd, 2014, 12:00 PM
rankar's Avatar
rankar
Well done. Onward.
brake, ht, lights
Formula R1X Disc Brakes - Mountain Bike Brakes bjf The Flea Market 4 May 14th, 2012 10:07 AM
Right running lights/headlight don't work red64chevelle Defender Technical Discussions 1 August 8th, 2011 09:56 PM
Left brake lights work....the right and door brake lights won't? beko35 Defender Technical Discussions 4 June 27th, 2009 02:12 PM
Turn Signals (rears work, fronts don't) cmcarp Defender Technical Discussions 2 September 5th, 2006 04:55 PM
Help - My 90's headlights don't work solihul Defender Technical Discussions 5 May 20th, 2005 01:27 AM
