hazard/flasher relay buzzes - Defender Source
Old May 9th, 2015, 08:27 AM
My hazard lights have not worked in a while and the relay just buzzes. So I bought a PRC8876 and just swapped it in, but it buzzes too. This is the left most relay behind the fuse block on a 94 NAS D90
Any suggestions on how to troubleshoot this one? My turn signals work fine.
Originally Posted by pendy
I'm here for the D's
Old May 9th, 2015, 08:51 AM
Bad ground or bad connection is guess. My ARB relay (long time ago) buzzed when it had a bad ground. My hazards on the 90 click/buzz because the pin connector on the back of the fuse panel has a poor connection...when I push the fuse in it stops (just haven't had a chance to pull it out and snug it up).
I'd start there and just poke around on the connectors or find the ground and check it.
relay
Flasher relay for LED blinker lights Reese_D90 Defender Technical Discussions 108 December 9th, 2017 05:11 PM
Defender flasher relay prc8876 Ben01 For Sale - Parts 2 April 7th, 2014 07:08 PM
1987 Ex-MOD 90 flasher relay 1953lr80 Defender Technical Discussions 0 March 23rd, 2014 06:48 PM
Electronic Flasher Relay - LED Compatible. ajh Defender Technical Discussions 1 October 22nd, 2010 09:00 PM
Flasher Relay Part Number for 97 d90? KKilo23 Defender Technical Discussions 3 May 20th, 2010 09:45 PM
