Has anyone tried these? Do they work? - Defender Source
Old January 12th, 2006, 12:25 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
http://www.roverparts.com/ProductLis...artNumber=8987
Sure would be nice to put an end to the rattling over every bump...
~Scott T.
'95 D-90 ST - AA Yellow
Old January 12th, 2006, 01:16 PM
Krna
Andy Krna
1997 D-90 ST AA Yellow
I asked the same thing last month:
http://www.defendersource.com/forum/...ead.php?t=7182
Apparently George at RDS has them cheaper, but have not heard if anyone has actually tried them.
Old January 12th, 2006, 01:26 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Thanks for the link Andy, I missed that in my search (honest I did search first). Hopefully Dave will respond back with hwo well they did or didn't work...
~Scott T.
Old January 12th, 2006, 01:37 PM
Krna
Andy Krna
I was hoping to hear from someone that has used these, it just seems like a much more reasonably priced fix than getting a whole new rear tire carrier setup.
Old January 12th, 2006, 03:46 PM
artm
Arthur Maravelis
97 SW
1. If you only care about the noise I would try just fitting a rubber or poly washer on either side of the wheel and tighten it up. I have the stock setup and when tightened down I don't hear anything. You may also try a poly sleeve on each extension. There's a high density polypropelene out there. I've seen it used as sheets between leaf springs to thwart rusting and noise, there should be tubing available.
2. If you want to fix the problem then you need to get a tire carrier that's up to the job. I'm waiting for the day when my tire breaks off the back (33x12.5). I don't see how a 35 can hold on for too long.
Old January 12th, 2006, 06:30 PM
I am responding right here, right now!
NO
Still rattles and drives me nuts. I think I am going to fab up my own tyre carrier.
Old January 12th, 2006, 07:53 PM
Krna
Andy Krna
Yeah, any time i drive down the highway and look at my 33 rattle away i am always waiting to look back and see it bouncing down the road.
Sitting at work JBurt Misc. Chit-Chat 104 December 23rd, 2016 08:13 PM
JC's Rover & 4x4 - anyone need any work done? JCRover4x4 Defender Technical Discussions 3 July 11th, 2011 04:24 PM
How do I get my radio to work???? Chris Cox Defender Technical Discussions 5 May 31st, 2008 09:49 PM
Employment opportunity Rod Hayward Misc. Chit-Chat 18 December 20th, 2005 10:20 PM
body work on aluminum mattdh Defender Technical Discussions 11 July 4th, 2004 02:47 PM
