Has anyone installed Webasto or Espar heater? - Defender Source
Old October 16th, 2006, 08:35 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Getting ready for winter and I want to install a coolant heater in my 300Tdi and wonder if anyone has actually done this?
what did you install and more importantly where did you get it? URLs would be helpful...
thanks
George
Old October 16th, 2006, 09:05 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
You might ping Sheki on this board, I believe he did one. I've been considering whether to install one as well. The engine just does not heat up fast enough.
Old October 17th, 2006, 09:50 AM
Michael
Michael
Discovery 1998
Yes, An Espar. Very nice piece of equipment. Sounds like a jet engine when it is firing up (just so you don't have to change you underwear when you first turn it on, like I did).
some info on espar here:
http://www.lubricationspecialist.com...html=espar.htm
http://www.espar.com/pdfs/hydronic4_5.pdf
Old October 17th, 2006, 11:17 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
The first time I fired it up, I thought I had converted the truck into a Harrier Jet. Thought the truck was going to take off.
Originally Posted by MuddyOval
Sheki, you are a wang too.
A wang is another word for, you guessed it, A DICK!
Nothing racist, just pure DICK!
Old October 17th, 2006, 11:36 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Do you crap your pants when jets fly by?
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 18th, 2006, 07:46 AM
Gkase's Avatar
Gkase
George Kase
can you guys describe exactly where the espar unit gets mounted in the engine compartment? also, do you need to drop the fuel tank and run new fuel supply lines to it?
thanks
George
Old October 18th, 2006, 12:48 PM
Michael
Michael
Discovery 1998
Yes, but if they're that close, the afterburners usually take of the mess.
This is for a Discovery, but you can do a search on this forum for "International HS2.8L", choose the thread that is very long (20 some pgs). Go to pg. 20, and there you will find a picture of a Discovery's engine bay
Old October 18th, 2006, 10:42 PM
Gkase's Avatar
Gkase
George Kase
Michael,
are those bright blue hoses leading to the espar unit by the coolant overflow tank?
Old October 19th, 2006, 01:26 PM
Michael
Michael
Discovery 1998
Originally Posted by Gkase
Michael,
Yes. I apologize for not specifying that. It is oriented "flat" as it would be if the unit was set on a table. At first, I was no sure if it would work this high up in the coolant circuit, but it does
Old October 20th, 2006, 07:03 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Alright, can one or both of you post some close-up pics of your Espar?
Btw, anyone used their aux cabin heater?
Old October 20th, 2006, 10:11 PM
Gkase's Avatar
Gkase
George Kase
I second David's request...also as a note about my shopping...one supplier suggested that the espar 5 was easier to mount because it comes in two smaller units that are easier to fit than the "smaller" espar hydronic 4 which is the smallest one piece unit...anyone know more about this?
Old October 30th, 2006, 12:55 PM
Tom Morrison
Tom Morrison
94 NAS 90 (300 TDI)
I'd also appreciate any info on the install with respect to fuel supply on a 300 TDI. Did you run a new line from the tank or did you T-off the existing line, and if so where did you T-off from????
Cheers, Tom
Old October 30th, 2006, 01:21 PM
Michael
Michael
Discovery 1998
Will post some close-ups by this weekend of mine.
I Teed from the existing fuel line, the one from the fuel filter to the fuel pump. In this configuration, the unit might not work while driving as the engines fuel pump wins the battle at the T. I did not plan on using it while driving, so I did it this easy way,
I have the D5, and it is just a one piece unit from 2003 model year. I am not familiar with the two-piece units.
Old October 30th, 2006, 03:50 PM
Tom Morrison
Tom Morrison
94 NAS 90 (300 TDI)
I read in the manual that the Espar's pump was not to be on the pressurized side of the lift pump. I'm not sure if that only applies to the gasoline models or the diesel versions as well. Just wondering if it might cause fuel to leak into the Espar when the engine is running.
Cheers, Tom
Old October 31st, 2006, 01:17 AM
whistler110's Avatar
whistler110
Mike Johnstone
ex-mod 110
I have an older D5 on it's way to me now and I've been doing some research, if you're interested I have a diagram showing the install into the military defender's if that would help. I was told to tee off of the engine bay fuel filter.
Bike Mike
Old October 31st, 2006, 07:32 AM
Gkase's Avatar
Gkase
George Kase
Mike...Yes! very interested in that info...can you scan and email or fax? I am really interested in the fact that they T off in the engine bay and don't mess with dropping the fuel tank and so on...
thanks!
George
Old October 31st, 2006, 08:46 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I would give the ESPAR its own pickup in the fuel tank to keep the formation of air bubbles from starting. The fuel line is a pain to bleed out . If you tee in up high it will continue to form air bubbles after the initial bleeding.
My 2cents
JP
legend in my own mind
Old October 31st, 2006, 10:30 AM
Tom Morrison
Tom Morrison
94 NAS 90 (300 TDI)
thanks!
George
I'm also interested Mike.
Thanks, Tom
Old November 1st, 2006, 06:44 PM
whistler110
Mike Johnstone
ex-mod 110
I have scoured through my manuals and gotten what I could find. I have the rave manual for the Wolf and that had the most info, 12 pages worth. I have them in jpg format and would be happy to send them along.
I mentioned someone Teeing off in the engine bay, but I can't find that info. What the Wolf does is take the fuel from one of the unused taps on the sedimentor at the back of the truck and pumps it forward.
Bike Mike
Old November 2nd, 2006, 11:07 AM
Michael
Michael
Discovery 1998
Mike,
Thanks for posting the diagram. I should have done it this way instead of cutting a nice stainless steel mesh covered fuel line.
heater, webasto
Espar as PRIMARY heater for D90 nikojo Defender Technical Discussions 13 March 9th, 2009 01:09 PM
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
110 Heater Hose Routing newfD90 Defender Technical Discussions 11 February 1st, 2006 02:02 PM
Webasto Heater roverx Defender Technical Discussions 1 November 29th, 2005 06:37 PM
Heater Improvements? And Hi ... again.. EdF Defender Technical Discussions 6 September 13th, 2005 01:51 PM
