Has anyone ever modified the rear bulkhead bar so you can install reclining seats? - Defender Source
Old August 30th, 2011, 02:51 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Question Has anyone ever modified the rear bulkhead bar so you can install reclining seats?
I think this is the only part of my D90 that I hate (well one of the few things). There are times where I just want to recline my seat and streeeeetch my legs. Especially after a long drive or if I'm waiting for someone. What if you bent a new rear bulkhead bar that is more vertically matched to the tub wall so that you can recline a seat all the way back. Possible? Also can you modify a D90 seat to recline all the way back? Can't remember if we could.
Robert Deniro
Old August 30th, 2011, 03:02 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Wouldn't those massive subwoofer boxers get in the way?!?
Old August 30th, 2011, 03:05 PM
Neil McCauley
Neil McCauley
I took the 15inch kicker and box out and replaced it with 2, kicker 8's for now. :D
Robert Deniro
Old August 30th, 2011, 03:46 PM
T1G UP's Avatar
T1G UP
marcus
Puma 110 xs. Td5 110 xs for sale
remove the bulkhead altogether?
2011. 110 XS SW. 1999 TD5 110 XS SW Project For sale
Old August 30th, 2011, 03:52 PM
Neil McCauley
Neil McCauley
On our NAS trucks we have what you guys call a bulkhead removal bar. Problem is it dosen't allow much of a recline angle.
Robert Deniro
Old August 30th, 2011, 08:32 PM
CDeWan
Clay DeWan
5.3L beastie
reclining
Neil,
Do you have a set of the Mud U.K. seat extenders? It moves the seat back and over the seat box to tub sheet metal? It gives you more leg room and you sit a bit higher.
Clay
Old August 31st, 2011, 12:42 AM
Chris Vitale's Avatar
Chris Vitale
'95 D90 ST 2.8L TDi #2050
I have been looking for this...if you find someone to fabricate a replacement, count me in on a group buy.
Old August 31st, 2011, 04:34 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Originally Posted by CDeWan View Post
Neil,
Clay
I found the trouble with those extenders, is it raises the height of the seat (by 3/4") and, if you're tall like I am, you end up looking through the sun visors.
Old August 31st, 2011, 09:20 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Has anyone simply removed the bar? any ill effects?
Old August 31st, 2011, 09:31 AM
Mine was gone for a bit, as the previous owner had installed a Tuffy console, must have forgotten to install the spacers, and said to hell with it. Of course it could just be perception, but I think re-installing it stiffened the body up quite a bit, in a good way. When I used to go around turns with it removed, I would once in a while get a door that would swing open, which I attributed to the body twisting/flexing a bit...because when I re-installed the bulkhead W bar, the doors stopped swinging open. It obviously ties the whole roolcage together, too, which is always good.
Old August 31st, 2011, 12:43 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
I have them installed in both front seats.
Yes, if you are in pole position at a traffic intersection, you have to see 'under' the visor for the light change, but the added comfort of the additional leg room and being able to recline the seat that much more makes it worth it. For reference, I am 6'4".
The other nice thing is it gives you a little bit of room under the seat to store the big maglights and a holster for a full frame hangun (if thats your thing).
mod, seats
License Plate LED Lamp & Rear Fog Lamp Install LenB Smaller Projects 24 December 16th, 2007 08:54 PM
fabbing sway bar mounts J.5 Defender Technical Discussions 1 September 13th, 2007 02:26 PM
4 Rear Jump seats, mint dmarchand For Sale - Parts 11 October 15th, 2005 03:00 PM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
Rear Brake Light Bar or Antenna boshea Wanted 3 September 9th, 2005 07:55 PM
