Harmonic damper - Defender Source
Old September 17th, 2016, 12:40 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Harmonic damper
It has come to my attention that my 300Tdi lacks a harmonic damper.
I know I want one.
Is this generic or specific? Will any 300Tdi HD work? Does anyone have one for sale?
Mike & Carrie
Defenders draw attention. Don't buy one if you're shy!
Old September 17th, 2016, 02:15 PM
Aren't they the same as disco ones?
Old September 17th, 2016, 03:02 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Don't know, that's why I'm asking.
Mike & Carrie
Old September 17th, 2016, 06:12 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
You mean the crank pulley (damper) - ERR2220?
Same on all 300tdi, sure we have a few in stock.
Old September 17th, 2016, 06:19 PM
You need to be a little more specific as to what you are looking for. don't think it is possible to not have the one on the engine. Perhaps get whoever to you that you need one to post up what they are talking about.
Old September 17th, 2016, 06:21 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
British 4X4 of Reno changed the IP on my 300Tdi (a Disco engine transplanted to my '88 Defender.) When I picked it up, I was told the harmonic damper is missing. Unfortunately, the owner Brian is the one with the details, but he is elk hunting this week.
I assume I pull the bolt on the end of the crank, line up the damper to the key and re-torque the bolt?
If all 300Tdi dampers are the same, I'm interested. If there are a variety of 300Tdi dampers, what do I need to know to get the right one? What is your price?
Mike & Carrie
Old September 17th, 2016, 06:34 PM
The engine's harmonic dampener is integrated into the crankshaft pulley. It is not possible to have a running engine without it. There must be some confusion. There is only one crankshaft pulley/dampener.
http://www.allbrit.de/UNI.cfm?PAGE=748626&SPRACHE=EN
Old September 17th, 2016, 08:21 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Mike & Carrie
Truck is running? No ancillaries without the damper/pulley as it drives the belt running the alternator, fan, steering, and water pump. I suppose you could run the truck without, but not for more than a few seconds...
May need to get some clarity from the shop on what is "missing" or if yours is damaged (rubber isolation layer splitting, or hardened)
Or they may have meant that the "flinger" is missing - the part behind the damper
Old September 18th, 2016, 12:08 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
My pulley/damper, not right side up.
Is this the correct part?
Mike & Carrie
Old September 22nd, 2016, 10:01 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Bump.
Does the picture of my crank pulley (message #9) look like the correct part?
Mike & Carrie
Old September 22nd, 2016, 10:05 PM
I have 3 300tdi powered trucks here (2 I've just done timing belts on) and they all have exactly the pulley you/John picture and nothing more.
Defender 3.9 Harmonic Balancer kite_eating_trees Wanted 1 August 26th, 2013 06:09 PM
In a pinch.....Harmonic Balancer failure? kite_eating_trees Defender Technical Discussions 4 July 15th, 2013 04:07 PM
Harmonic Crank Dampner jjstahl3 Wanted 1 July 18th, 2012 06:41 PM
Anyone have an alternator pulley and a harmonic balancer they can measure? Turbofan Defender Technical Discussions 0 October 21st, 2011 10:35 PM
Harmonic Balancer woldd90 Defender Technical Discussions 2 April 3rd, 2006 07:11 PM
» Defender Registry
Sold
Tippy
K2atlanta
Add your Defender
