Hardware Specs for Rear Cage (ST)? - Defender Source
Old April 7th, 2014, 11:33 AM
Holiday's Avatar
Holiday
Ross Simpson
1995 D90 ST/2006 D3 HSE7
Replacing my tub cappings with a galvanized version from YRM Solutions (Factory LR Part), and would like to replace the cage's mounting hardware at the same time. Rovers North has the bolts, but they apparently don't know sizes and quantities.
Haven't removed the cage yet, but it appears that there are:
Front Hoop- 3 Torx Bolts/side
Middle Hoop- 2 Torx Bolts/side
Rear Hoop- 2 Torx Bolts/side
Can anyone tell me the bolt sizes and quantities necessary to do the job? Is there any hardware unseen that I would want to replace underneath the foam? The truck is a NAS 95' ST.
Thanks!
Ross
Old April 7th, 2014, 11:50 AM
http://www.defendersource.com/forum/...ad.php?t=37641
Old April 7th, 2014, 12:06 PM
Holiday's Avatar
Holiday
Ross Simpson
Originally Posted by rijosho View Post
Perfect- thanks Josh!
So the bolts are Torx T-50 heads M10 -1.50 x 3.175. Can anyone verify that my count of 14 is correct? Charles's picture in the link shows 20, but I would expect this was simply a 20-piece kit that was for sale.
Also- it appears (at least from this thread) that a stainless version with the same hardness was not found. Since then, has anyone come up with one?
cage
Help w/bolt specs- D90 rear seatbelt Bradford Defender Technical Discussions 2 May 16th, 2013 07:40 AM
Misc ROW Softtop hardware / Tailgate Hardware SafariHP The Vendors Loft 0 February 19th, 2009 09:45 AM
NAS D90 Specs JohnK Defender Technical Discussions 13 April 7th, 2005 12:05 PM
86 D90 Brakes, Specs? Larns Defender Technical Discussions 4 June 9th, 2004 06:55 AM
anyone know the model # / specs januconn92 Defender Technical Discussions 1 January 23rd, 2004 09:42 AM
