Hardtop Rear Gas Shocks Replacement Question!!! - Defender Source
Old November 7th, 2013, 05:59 PM
thehundredth
PJ
1995 D90 Beluga Black
Ok. I need to replace the rear gas shocks off a NAS fiberglass hardtop. OEM #ALR8360. I simply want to know if I can replace with this: #MXC7833 gas strut. It's the SAME size, looks EXACTLY the same, even made by the SAME company! But, of course, since the OEM was produced specifically for the defender, it costs 10x more! When I asked the parts rep, of course, he says "It's different". Can anyone help me with this??? Have you replaced your shocks with another brand or part number without a prob???????
Old November 7th, 2013, 06:05 PM
I could swear that AmityD90 already told you exactly what to buy for struts in one of the other door shocks threads you started. Search your own threads...
Old November 7th, 2013, 06:07 PM
jafir's Avatar
jafir
Jafir Elkurd
probably has to do with the weight of the hatch.
Old November 7th, 2013, 06:10 PM
thehundredth
PJ
You know whaaaaat, you're right! A couple of months ago??? Nuff said. Josh? You need a vacation away from that computer
------ Follow up post added November 7th, 2013 03:13 PM ------
Ahhh. Ok. Thats why there are such price differences. That makes sense.
Old November 7th, 2013, 06:13 PM
Same as the ones on a RRC upper tailgate I believe, MXC7833.
The only difference with all gas struts will be in the rating of the strut. They usually come in a wide range of forces from 15 lbs to over 100. A strut can be identical in every way...size, length, and yet be far different in lift force.
Pretty sure the ones you are asking about will be just fine. Only problem I can see is that if the tailgate is too light weight it may be harder to close with stronger struts.
Old November 7th, 2013, 06:23 PM
thehundredth
PJ
Thanks, Bill. This is what I needed to know. Even the one's AmityD90 suggested are over $80 EACH! Heading back to ebay to purchase. Thanks all.
Old November 7th, 2013, 06:29 PM
jafir's Avatar
jafir
Jafir Elkurd
You can get the range rover part (aftermarket) from rock auto for less than $10.
ac, gas, hardtop, top
Another rear bumper question TexasD-90 Defender Technical Discussions 26 December 31st, 2010 08:52 AM
Rear Door Replacement Options Defender 110 COSteve Defender Technical Discussions 17 March 10th, 2010 12:12 PM
Need replacement locking gas cap vnrover Defender Technical Discussions 17 April 10th, 2004 04:29 PM
Stock D-90 replacement shocks... OCD90 Defender Technical Discussions 6 December 19th, 2003 09:25 PM
OME shocks are too long on rear axle... wicks Defender Technical Discussions 5 October 6th, 2003 02:39 PM
