Hard to turn steering wheel when AC is turned on! - Defender Source
Old May 29th, 2010, 08:53 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
OK help me out here what would cause the rpm's to drop from the normal 600 rpm's to 400 rpm's at idle ? the steering wheel is also harder than hell to turn. I know there will be drag on the system from kicking on the AC but this is ridiculous. should the motor bump up rpm's to make up for the load on the system?
ac, wheel
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
Steering wheel adapters Buckon37s Defender Technical Discussions 109 July 1st, 2007 09:19 PM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
