Hard to start - Defender Source
Old October 29th, 2014, 08:48 PM
9492
Shawn
1994 Defender 90
Hard to start
My 1994 Defender 90 is difficult to start. I have to crank it for up to 15 to 20 seconds and give it gas to get it to start. It doesn't seem to matter whether the engine is cold or hot. It was recently tuned up with new plugs and wires. The fuel pump is also new. Any ideas what could be wrong? Thanks
Old October 29th, 2014, 09:02 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Bad coil?
Old October 29th, 2014, 10:08 PM
Any codes?
Fuel filter.
Air idle control valve
Bad connection from coil to ECU.
Air leak
Old October 29th, 2014, 10:26 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I'd go straight to the IACV and check. Easily swapped out too, if it indeed bad. Clean first--and some people remove the spring on the shaft. Some don't. It can directly affect starting and idle when dirty or failed. There is a good article on cleaning it and checking it-- you can/should remove it and make sure the plunger goes in and out with toggling the ignition. There is a decent write up on here but I'm on a mobile device so too hard to find it for you right now.
Old October 29th, 2014, 11:33 PM
9492
Shawn
1994 Defender 90
There are no codes, the coil is new, the filter is new
Old October 29th, 2014, 11:41 PM
Pull the plugs and see if they are wet or oily.
start
hard start / rough idle after, mostly during wet condition corrumpu Defender Technical Discussions 2 August 20th, 2012 11:21 AM
Start no start leastonce Defender Technical Discussions 10 February 25th, 2012 02:33 PM
Sudden Stall Then Hard Start artpeck Defender Technical Discussions 11 January 16th, 2010 10:38 PM
Occasional Hard To Start and Now The Engine Spontaneously Dies artpeck Defender Technical Discussions 3 June 23rd, 2009 09:49 PM
easy to start/hard to keep running hamiamham Defender Technical Discussions 0 July 7th, 2008 10:19 AM
» Defender Registry
cjbenway
Big Blue
Bmwrovers
Add your Defender
