Hard starting while cold. - Defender Source
Old December 5th, 2008, 03:51 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Ok, I'm going to start fresh on this one, since I'm obviously too far along and missed something. This problem also seems different from the last one, so I'm going to just clear the slate of ideas and see what's going on.
Recently upgraded to a Mallory distributor and coil. Swapped in a 4.2 ECU, in place of the original which I no longer have.
Intermittently the truck will crank fine, but won't catch. Once it starts, it runs just fine. I'll poke under the hood, wiggle a couple wires, and usually it will start right up. I honestly don't know if my testing is actually doing anything. Today it wouldn't catch, and I flooded the hell out of it. Brought it home on a flat-bed, after sitting a couple hours, and of course it started right up once it got home.
Spark is good at the coil and at the plugs. Fuel pump is humming along and sounds good. I tried resetting the ECU, with no effect.
Seems to be more of an issue when the engine is cold. Battery cranks the starter good and strong for quite a while before finally running down.
My oil line fix
My 100k stopped odometer fix
start, starting
Hard Starting 94 D90 Raleigh D90 Defender Technical Discussions 1 April 6th, 2009 11:21 AM
Hard Starting...ARG!! arbik Defender Technical Discussions 10 November 7th, 2006 01:08 PM
Hard Top for the Cold Winter DrewC Wanted 2 May 1st, 2006 11:55 PM
Hard Top for sale Mark Cama For Sale - Parts 0 August 31st, 2005 09:19 AM
Hard starting, everything else fine? Doug Defender Technical Discussions 16 July 11th, 2004 01:25 PM
