Hard starting...FPR? - Defender Source
Old November 30th, 2010, 11:16 AM
I suspect the fuel pressure regulator on the Loob may be bad. Not sure, but ever since the head gasket thing, it has been hard to start after sitting over night. Takes maybe 4 tries to get fired instead if the usual half a crank. Once it is going no issues. Clearly it is not getting fuel at startup.
Only thing different than before is the vacuum hose to the FPR is actually working now as it was dry rotted off before.
It seems odd that the engine is harder to start now that it has been all sorted out whereas before it was spewing from between two cylinders, and had a bad tappet.
start, starting
Hard Starting 94 D90 Raleigh D90 Defender Technical Discussions 1 April 6th, 2009 11:21 AM
Hard starting while cold. Hans Defender Technical Discussions 0 December 5th, 2008 03:51 PM
Hard Starting...ARG!! arbik Defender Technical Discussions 10 November 7th, 2006 01:08 PM
Hard Top for sale Mark Cama For Sale - Parts 0 August 31st, 2005 09:19 AM
Hard starting, everything else fine? Doug Defender Technical Discussions 16 July 11th, 2004 01:25 PM
