Hard starting, everything else fine? - Defender Source
Old July 2nd, 2004, 01:56 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
I have one bug trying to fix on the new 5.0 install in my 93 NAS 110. It's actually a problem I've had for a few months, but seems worse with the new engine -- and that is it takes numerous cranks and tweaking the gas to get her to fire up. Truck has a very recent new fuel pump and filter.
Once running, idle is fine, no hesitation, revs are great, no fault codes. Anyone have a simple checklist for this issue?
Old July 2nd, 2004, 02:30 PM
just a thought but......... maybe the starter was getting worn with the 3.9 and now with the larger motor the effects are more noticable? just a thought isnt thte 5.0 higher compression etc?
Old July 2nd, 2004, 02:54 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Doug, did you replace the whole fuel pump assembly or just the pump it self. I had the same problem with mine and it turned out the sender hose from the pump was loose.
World traveler
Old July 2nd, 2004, 03:23 PM
Doug's Avatar
Doug
Doug Walker
Ahhh, good idea! I'll check that, Yousef. Phil, the engine came with new starter -- it cranks fine, but thanks for the idea.
Can any of the various senders cause a hard start as above?
Old July 2nd, 2004, 04:04 PM
how's the battery. j-jk
Old July 2nd, 2004, 05:05 PM
Doug's Avatar
Doug
Doug Walker
Just read on LRX that bad fuel and coolant temp sensors can cause this prob. Have to check them. Phil, batt is good!
Old July 2nd, 2004, 05:42 PM
neo812's Avatar
neo812
Kris
1985 Tithonus
Doug, seems as though you have found my suggestion. Both of these items can cause the problems you are mentioning. Buy genuine. I matched the sensors at NAPA when I was tracking down the same problem. They did not fix it and now I have a toolbox full of useless sensors. The genuine seemed to do the trick.
Motorcars LTD. in Houston has about the best prices on those sensors.
Old July 9th, 2004, 04:32 PM
Doug's Avatar
Doug
Doug Walker
Well, the sensors are all the new ones with the new engine. Can't be them. Fuel pressure seems fine. But we noticed that when the starter is cranking, there doesn't seem to be much spark. Alternator is new, battery is a year old yellow top that seems fully charged.
Any ideas what could be sucking off ignition spark only when the starter is cranking?
Old July 9th, 2004, 05:04 PM
Robbie Donaldson's Avatar
Robbie Donaldson
Robbie Donaldson
1995 Discovery
is this a distributor or gems truck? if a distributor, i would look at the rotor and cap. possibly even the coil.
had a rotor go bad on my 3.9 and made very weak spark at the plug wires, to the point wouldn't even start.
Old July 9th, 2004, 05:27 PM
Doug's Avatar
Doug
Doug Walker
New coil, and its the spark coming from the coil lead to the disty that dips on cranking. Let go the starter, and the spark improves. BTW, the problem was present before new engine and new starter motor.
Old July 9th, 2004, 10:32 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Doug how many wires do you have going to your coil? You may have dropped one on the eng swap? Only a stab in the dark! Ignition module?
How bout checking the amplifier switching. Iwill try to scan & post if needed.
Peter
Old July 9th, 2004, 11:21 PM
Doug's Avatar
Doug
Doug Walker
Wow, maybe! How many wires are supposed to be going to the coil pos and neg? Amplifier is only 5 months old....
Old July 9th, 2004, 11:37 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Doug, 2 white pos 2 white neg & the little black to what ever that is on the fender. Do you wana pic? I pulled my coil& turn it upside down so you can see.
Old July 10th, 2004, 11:37 AM
Doug's Avatar
Doug
Doug Walker
Can you post the pic? Thx
Old July 10th, 2004, 09:47 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I will tonight! I was racing all day & I am spent.
Peter
Old July 11th, 2004, 12:52 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
they are not the best but hope they help
Name:	110 ig 001.jpg
ID:	988   Click image for larger version
Name:	110 ig 002.jpg
Name:	110 ig 003.jpg
ID:	990   Click image for larger version
Name:	110 ig 004.jpg
Old July 11th, 2004, 01:25 PM
Doug's Avatar
Doug
Doug Walker
Thanks Peter -- I'll match these up tomorrow and let you guys know if all the wires are in place!
start, starting
Hard Starting 94 D90 Raleigh D90 Defender Technical Discussions 1 April 6th, 2009 11:21 AM
Hard starting while cold. Hans Defender Technical Discussions 0 December 5th, 2008 03:51 PM
Hard Starting...ARG!! arbik Defender Technical Discussions 10 November 7th, 2006 01:08 PM
Hard Top for sale Mark Cama For Sale - Parts 0 August 31st, 2005 09:19 AM
Not starting '95 what to check next. jcasteel Defender Technical Discussions 17 June 10th, 2005 02:38 PM
